tranny shot - SaabCentral Forums
Old 14-05-06
NuMlOcK NuMlOcK is offline
My Saabs: 1990 saab 900 turbo SPG!!!
Exclamation tranny shot
i have a 1990 saab 900 spg (5-spd) and the problem is that the transmission is clunking like something is loose or broken. it will move but it feels like the tranny is gonna explode. so its just sitting for now.
it started when i was shifting from a stop into reverse and the gears grinded reallllly bad! it felt like the car broke. but now the tranny clunks about every complete tire rotation or so.
is my tranny done for? or can i fix this?
also when i am in neutral the clutch makes a funny noise, until i press the clutch pedal to disengage it, and then the noise goes away. its not very noticeable but it wasnt there before.
thx
Old 14-05-06
900t's Avatar
900t 900t is offline
Saabista
Yeah tranny is junk I'll take that car off your hands
In the least pull the engine/trans and take apart the gearbox. The failure will be pretty obvious.
Old 14-05-06
what would a fix cost?
ive heard about 2k for a new tranny?
Old 14-05-06
900t's Avatar
Saabista
Well it depends how you want to go. You can get used trannies for free if you're lucky. You could rebuild yours, maybe. With this kind of thing the prices vary wildly. Who is doing the work?
Old 14-05-06
id be doin the work, but the problem is figuring out whether or not my tranny is rebuildable. =[
Old 15-05-06
Matthew's Avatar
Matthew Matthew is offline
Saab Mad
My Saabs: 900 S Aero Turbo, 9-5 Aero
Clutch release bearing. Instructions for replacement here:
http://www.saabcentral.com/forums/sh...ad.php?t=35662
Sometimes you can get the slave out without removing the clutch pressure plate.
The path of my life is strewn with cowpats from the devil's own satanic herd
Old 15-10-07
SaabStory60 SaabStory60 is offline
My Saabs: 1988 Saab 900 SPG
A little bump.
The Saab I'm looking has a nastly clunk spinning sort of sound when the clutch is out. When the clutch pedal is in the sound goes away. The seller is sure that its the throw out bearing. but I always thought throw outs made the sound when the clutch pedal is in but silent when the pedal is out. Any help would be great!
1988 SPG awaiting tranny work
Currently driving a 1984 Toyota Landcruiser FJ60
Old 15-10-07
ShadowWorks's Avatar
ShadowWorks ShadowWorks is offline
Banned
My Saabs: The Black Night, 900T
It could be your innecr CV joints, is there any play in them?
Old 15-10-07
This happens when its just sitting not going anywhere. So it wouldnt be the CV's.
Old 15-10-07
Jim Mesthene Jim Mesthene is offline
Originally Posted by SaabStory60
...I always thought throw outs made the sound when the clutch pedal is in but silent when the pedal is out.
That's usually the case.
Corporations are people! If you prick them, do they not bleed? If you tickle them, do they not laugh? If you poison them, do they not die?
Old 15-10-07
Matthew's Avatar
Saab Mad
Can also be noisy primary chains (yes it does happen).
Old 15-10-07
jdmckay jdmckay is offline
My Saabs: 1986 900S Sedan
Our local U-Pull yard sells the trannys for $79. Last time I was down there, around 9 c900(s) were there. I'd consider looking around for similar yard (where in USA are u?).
Old 16-10-07
cdaly's Avatar
cdaly cdaly is offline
Moderator
My Saabs: '92 900LPT, '90 900i vert
One of mine is silent with the pedal in but 'sings' with it out.
Ok, I have the flight booked. Can you meet me at the airport?...
Old 16-10-07
Just bail out about 500 ft. before your plane hits the runway... you'll be in the yard. Aim for east side (imports), rows 6-33. It's a... "fully self-service yard, you pull you save", so don't forget your tools!!!
Old 17-10-07
Banman's Avatar
Banman Banman is offline
My Saabs: 91 900s turbo/ezk hybrid
cdaly--fly to Denver instead--it's cheaper! You supply the guiness, I'll pick you up and supply the tools!
How much are used trannys in Ireland?
Banman
'91 16vT
'75 IH Scout
Old 18-10-07
cdaly's Avatar
Moderator
About as much as hen's teeth. Pretty hard to get at all. Probably in the region of EUR350 (USD500)...
Old 18-10-07
woywitka's Avatar
woywitka woywitka is offline
My Saabs: '87 900 T16 vert, 911 SC,914,W123 Diesel
Let's remember that is is CRITICAL c900 owners with Manual Gearboxes shift into a foreward gear before selecting reverse so that extensive damage is prevented.
STEP 1) You ALWAYS need to be at a full stop.Depress the clutch then select and foreward gear before selecting reverse(do not let the clutch out during this step).
Step 2) If the gear selector or "STICK" does not go in on the first try you must move the "stick" into neutral and then let the clutch out. Repeat step 1 again.
Fun times:
Classic Saab 900 Turbo Convertible, Porsche 911
Old 18-10-07
Honkey's Avatar
Honkey Honkey is offline
My Saabs: Saab 89 900i
Originally Posted by woywitka
*Proper way to get into reverse...*
My old man has an auto turbo 9000 atm,
1) Select R and reverse out of our driveway
2) While its still rolling back *slap* it into D
3) Proceed to cry as you hear this every morning
Drive it like you stole it!
