Blower problems - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9000 > Saab 9000 Workshop
Saab 9000 Workshop Saab 9000 (1985-1998) Technical Forum
Old 14-05-06
9000pimper 9000pimper is offline
My Saabs: BEAST
Default Blower problems
Wuts up guys,
i have had my 9k for a while but have not been using it much because of inadequate (prolly not spelled right ) funds but now that i got some money and am thinkin of makin this baby look good again first the blower is currently not working. But randomly the blower turned on the other day and blew hard but then won't work again. Has anybody had this problem with there 9k, if so could you tell me where your short was?
thanks ahead of time guys
Old 14-05-06
screamingreen97 screamingreen97 is offline
My Saabs: 97 900se
it could b a faulty fuse, try that first
Old 22-05-06
gettingold gettingold is offline
My Saabs: 1993 9000 cse 2.0lpt
Default blower fault
Hi
Im probably a week too late - have only just read thru the posts. Anyway - try your blower - if it only blows on full - then its the resistor pack.
Its a common fault apperantly, my 9k ate two in six months and I now have a couple of spares that have found there way into my toolbox on breakers yard visits! Of course now Ive got spares, the current one will outlive the car!
The resistor is attached to the side of the blower which is located behind the false bulkhead. Undo the bolts on the plastic cover at the back of the opened bonnet / hood , its located ( on mine anyway! ) to the right - feel around for the wiring connector. Unplug the connector and the resistor pulls out.
I can send pics if you want them.
I have seen resistors on ebay ( in the UK ) go for pennies.
Hope this helps
Paul
Old 22-05-06
klarking1075 klarking1075 is offline
My Saabs: MY98 9000 CSE B234R
Usually if a resistor pack blows, then what happens is that the fan will blow fine on full speed, but will not step down to the lower speeds.
2 questions...
1) Do you have AC or ACC?
2) Does the blower work at all at full speed settings
If you have ACC, then there are a number of issues that could cause problems (including ACC control module), but the best way to check the blower would be a straight 12V feed to it. If it runs full with this, then the blower is fine, and the problem is else where.
Take it logically, and use the search function on here to find possible answers.
Kenneth
Old 23-05-06
My Saabs: BEAST
well it only worked that one day for a few min. and it was on full now it won't work period. this is what leads me to believe there is a short somewhere.
Old 23-05-06
Have you run the diagnostic check on the ACC (if fitted)?
If the ACC control unit has packed up, then you would get issues with the aircon not working at all, as it controls the speed of the blower automatically. If you do a search on here, you should find the key combination for the ACC test mode.
If it passes that, then you really need to test the blower motor independantly of the ACC to make sure it's fine. If it passes that, then I'd start looking for shorts or broken cable, but until then start by checking the obvious.
Kenneth
Old 25-05-06
My Saabs: BEAST
thanks a lot guys i will do the ACC test then get back with you guys
