Stalling 9000 - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9000 > Saab 9000 Workshop
Saab 9000 Workshop Saab 9000 (1985-1998) Technical Forum
Old 13-05-06
hwrdall hwrdall is offline
New Member
My Saabs: 1992 9000
Angry Stalling 9000
I have a 1992 9000, lately it has been bucking and stalling out during slow speeds. This has been happening intermitantly. For example it will be cruising fine at top hingway speed,when I slow down at an intersection this is when it happens. I shut the ignition off then turn it back on then I'm on my way until it happens again.
Old 13-05-06
88nate9kt's Avatar
88nate9kt 88nate9kt is offline
My Saabs: 88' 9000t 233k miles
Thumbs up i have the same problem
only difference is i drive an 88 9kT ...im told from a local saab owner down the street who is the presidwnt of the san diego car owners club it is probobly the idle air valve (i think thats what he called it) a canister with teo hoses that sits on to of my intake not sure if you have it ....but ima clean it out with carb cleaner this afternoon and ill let you know how it goes that what he suggested i do before buying the 90$ part.....hope this helps ill post my results ...
Old 14-05-06
shortlid's Avatar
shortlid shortlid is offline
My Saabs: 2001 9-5 base, 5-speed manual , 220,000
Question Does it have TCS??
My '95 9000 Aero 5-speed has TCS and it was the ground strap to the ECU that casued it to stall after coming to a stop!!
Please help me take my 2001 9-5 Base 2.3 lpt, 5-speed with 220k on the clock to 300k!!
Old 15-05-06
Skunk Skunk is offline
New Member
My Saabs: '94 9000CSE
My '92 9000CS did exactly the same.
A new air mass meter fixed it for me.
Old 15-05-06
its_tricky83's Avatar
its_tricky83 its_tricky83 is offline
My Saabs: 9000 CD FPT '91
I had the exact same prob, stalling on coming to a stop, ended up being the Dump Valve stuck open, happens often. You can buy the part for around $50aus, it's a Bosche plastic thingo. If you can, fork it out for a Forge or something at least a bit better than the plastic peice of crap.
Old 15-05-06
Superaero Superaero is offline
My Saabs: 1997 Aero manual
Hooter valve is the most likely issue. Though made of cheapo plastic the stock part is more than up to the job. They do fail and the symptoms are as you describe.
Sometimes the little PCV blocking valve fails which can cause issues.
A dirty throttle plate can cause these symptoms.
The AIC valve is anvil reliable and although it might fail this is unlikely, extremely unlikely.
Old 21-05-06
fn0w fn0w is offline
My Saabs: 89 9000 cd 2.0 na
I had the same problem, it was the O2 sensor that was too slow, due to carbon buildup. My car stalled mostly after highway cruising, when slowing down and pressing the clutch.
Replaced the sensor with a cheap universal one and the problem was gone.
