Timing - gunsight? - SaabCentral Forums
Old 01-05-06
SteveTheFolkie's Avatar
SteveTheFolkie SteveTheFolkie is offline
My Saabs: 1987 900 8V
Default Timing - gunsight?
Just a quick question since my Bentley manual hasn't arrived yet - when I look at my flywheel I see a "gunsite" (round hole) with a line transecting it (well, if it was solid it'd transect it - as it is there's a gap where the hole is) - am I correct to assume that I set my timing (20 BTDC on my '85 NA) at that line? I didn't see any other fixed points of reference. Just re-set it yesterday and it's running fine - not pinging on 87 octane or dieseling when I shut it down (as it had been before) - so I figure I'm correct - but just wanted to verfiy -
Also can't recall a vehicle that uses three bolts to fix the distributor in place like the Saab does - thought I was getting weak until I found the one on the underside of the dist!
thanks
Steve
Old 01-05-06
jetman jetman is offline
My Saabs: 1984 T8
Yes and yes! Its really fun when you have a leaking dizzy o-ring and it gums up the bottom bolt.
Old 01-05-06
.... dealing with wires, vacuum lines and other stuff "hovering" above the gunsite is a real joy as well - someone had set the timing to 16V turbo (16BTDC) which was giving me a bit of a ping under load and a bit of dieseling when I shut down - so I figured it was advanced - brought it back (to 20BTDC - as specified in the manual) and all seems well - starts easier also (who'd have guessed?) -
thanks
Steve
Old 01-05-06
nutcase's Avatar
nutcase nutcase is offline
My Saabs: 1978 99T in black; 1983 99GL in Beige
The "gunsight" is for a Saab timing tool that is a sensor that reads the dowel in the flywheel. To use the timing marks on the flywheel there is a line in teh palstic cover, which is repeated on the engine itself if the cover is removed.
Photo Gallery
Old 01-05-06
... so I may still be off by 5 or so degrees (estimating the distance I think the line is from the gunsite - if my recollection of the line is correct - versus the diameter of the flywheel in degrees) - I'll give a look when I get home tonight - thanks for the additional information -
At least you can reach the distributor while poking the timing light down at the cover AND there's no mechanical fan to chew off fingers or timing light wires!
Steve
Old 01-05-06
My Saabs: 1984 T8
Steve
I lost a $200 timing light to a dufas friend I lent it to who sheered it off in the cooling fan of whatever domestic beast he was fixing. Now I have a $30 replacement. Which actually works just fine for me.
Old 01-05-06
nutcase's Avatar
I've broken many a cheap strobe Just bought a more rugged (and much more expensive!) one in the vauge hope I can use it more than once.
Photo Gallery
Old 01-05-06
a squared a squared is offline
My Saabs: '95 900S 2.3 liter non-turbo
Most Hondas are this way.
Old 01-05-06
.. which would explain why I've not run into one before. I drove a rather pathetic excuse for a car called the Honda 600 many many years ago - then I drove a CRX-HF for a bit - as a loaner from a friend while I was working on my VW - that encapsulates my honda experience. I've never been impressed by their vehicles - they always seemed to lack imagination and be rather bland. Perhaps when I retire in 25 years or so they'll "excite" me - but for now I'll pass, thanks. I've always migrated towards European vehicles or (for a few years in my mis-spent youth, when gas was cheap) American muscle cars ('63 Impala SS 409 dual-quad 4spd, 70 Buick GSX 455 4spd and (right before I got married) a 1969 Boss 302 Mustang 4spd) -
I'm not saying it's a bad design - just seemed a bit "overkill" to me -
Steve
