Eric, Some questions about your BOV mod. - SaabCentral Forums
Old 24-02-03
Tweek's Turbos Tweek's Turbos is offline
My Saabs: 07 9-5 Combi, 99 9-3 Viggen, 85 900 SPG
Default Eric, Some questions about your BOV mod.
I peeked in at your site again, specifically at the BOV mod. I'm guessing the 10" 1" diameter hot water pipe is a typical home depo Item, and the circle clamps a Napa thing, But how about the chcck valve thingy? What type of store/Isle can I find that in?
Old 24-02-03
ERP's Avatar
ERP ERP is offline
My Saabs: Turbo X 19T JZW Stg 4, 415hp 532tq
I was able to get everything at Home Depot. Nothing special about the check valve, I forget what isle I found it in. Total cost for everything was ~$15. It helps to enlarge the ends of the hot water line, its obvious when you try to fit it.
The sound of the BOV changes depending on the type of fittings you use between the hose and the check valve. Some setups are louder than others, I just messed around a bit with some different fittings until I found a volume that I liked.
Eric
Old 07-08-05
vertiblechickmag vertiblechickmag is offline
My Saabs: 1999 9-3 SE vert
i just checked home depot and they had a non-hinged brass check valve, and a hinged check valave that was 1" into a 1.25" outlet-both ends threaded. Neither me nor the guy helping me knew if it would hold up cuz it was not the most durable looking thing. They didnt have the hot water pipe in 2 or 1 inch, but i could use the tube thats in my car now for recirculation correct? and how important is the size of the hot water pipe on the exit side of the check valve?
also if i do this with home depot parts, is this thing going to mess with my car and will it perform/last?
Performance gains/losses?
Old 07-08-05
stromer's Avatar
stromer stromer is offline
My Saabs: 1999 9-3 SQR stage IV - 2002 9-5 Aero
nothing like resurreting a 2.5 year old thread!
Old 07-08-05
Marks900SE's Avatar
Marks900SE Marks900SE is offline
My Saabs: '99 9-3
If you have a slight chance of raising boost beyond stock via MBC, MBC+A, or ECU just forget this idea and look into an aftermarket BOV/BPV cause the stock PBV fails fast with incresed boost.
'96 900SE Turbo Stage 4 - RIP
'97 900SE Turbo - Gone
'98 900SE Turbo - Gone
'99 9-3 S - Underway
Old 07-08-05
no i dont, and if i do ill get something else. i just liked the idea of a 20 dollar bov on a stock setup
Old 07-08-05
julianBC julianBC is offline
My stock bpv failed literally after less than 2 miles. 3 pulls with my new mbc+a and it started honking. Bought a BOV off ebay for like $90 and its great. I had to put the stock bpv back on once and it was so awkward without the psshhhhh.
Old 28-04-07
hkayssi hkayssi is offline
My Saabs: 1997 900S
Eric
Eric, your site is down. It's been down for a few days.
http://www.ericsaabsite.com/
