Fantastic fuel economy increase! - SaabCentral Forums
Old 19-04-06
Daniel's Avatar
Daniel Daniel is offline
My Saabs: Classic 900 LPT/93 Sportwagon TTiD
Default Fantastic fuel economy increase!
I've been registering the MPG's for about the past 6 months. It's beed steadily increasing after various adjustments etc. : adjusting AMM, new plugs/leads and dizzy. New lambda/reset ECU and inflate tyres! It started at 20/22mpg and I got it to 24/26. (averaged, including all types of driving and conditions).
I decided to have the timing checked and it was out by 3 degress. At the same time as doing this I fitted a new 82 degree thermostat. The car was taking ages to reach op temp and I suspected it was holding the car on choke for too long.
The MPG's have jumped to 28/33! I'm getting 28 around town and 32/33 on the motorway.
Just a heads up really: if you're having poor economy and you've exhausted most other things, try the thermo and timing!
Old 19-04-06
unkleG'sif's Avatar
unkleG'sif unkleG'sif is offline
My Saabs: 1993 T16 (xLPT) - 1994 RUBY!!!
superb
guess i'll have to look at the same
cheers daniel
g
"we can allow satellites, planets, suns, universe, nay whole systems of universe[s,] to be governed by laws, but the smallest insect, we wish to be created at once by special act" - Charles Darwin
http://www.nicecupofteaandasitdown.com/
http://www.saabcentral.com/phpgallery/Gs-little-Saab
Old 19-04-06
SteveTheFolkie's Avatar
SteveTheFolkie SteveTheFolkie is offline
My Saabs: 1987 900 8V
great job! Some people have seemed astounded by my mileage (32-33 MPG) but I attribute it to keeping my car in a good state of tune, clean air filter, clean oil (and I don't go gonzo on viscosity) and keeping the tires aired up - amazing how many people are running around with a dirty air filter, poor lubrication, low tire pressuer with a bad running engine who complain about the lousy mileage they get.
Old 19-04-06
Matt88S's Avatar
Matt88S Matt88S is offline
My Saabs: 87&88S,88T,91TVert, 90 Talladega Red SPG
Not to spoil you good mood or anything but Summer fuel mix might also have something to do with it, you tend to slightly better milage on it. I went from about 28 mpg to 25 mpg when they switched from summer to winter and I've notice in the last month or so I've went back up to 28 mpg. I've forgotten exactly when they switch over but its a theory
Old 19-04-06
You could also take atmospheric conditions into account since warmer air is less dense and would provide less resistance, colder temperatures keep the enrichment circut open longer, the alternator is working harder (lights, wipers, heater blower motor, heated seats) and people tend to idle longer to let the car warm up, plus our cold lubricants provide more resistance until they're up to speed - and the winter fuel change over is a possibility - but mine was consistent through the winter (and we do use winter formulations in this part of PA) - you still can't beat a good tuneup, clean filters and correctly inflated tires -
Old 20-04-06
16saabs 16saabs is online now
My Saabs: 2x LPT convertible's, 1 x 900 SE
as others before have said, keep all your electrics newish and clean, good filters and oil, and timing. the only time i get below 31(norm 32-33 al seasons) is when i drive the wife's vert auto 25-27
Old 20-04-06
PianoDavid's Avatar
PianoDavid PianoDavid is offline
My Saabs: 1988 900 16v Turbo 3Dr auto.
ive heard about ignition timing but i have noooo idea how to check it. some kind of light needed?? plz help... im getting 20 and i WAS getting 25 before my new AMM was installed (i guess my older one was running lean?)
Old 21-04-06
You'll need a timing light (connects to your battery and the spark plug on the #1 cylinder) and a wrench (that fits the fixing bolt on your distributor) - with the engine at idle you aim the timing light at the timing mark (should be adjacent to the flywheel) - and adjust the distributors position - by turning - until the mark on the flywheel (which will be illuminated as the strobe light in the timing light is activated by the ignition pulse from the #1 cylinder) is aligned with the timing scale mark that is required - you then tighten the bolt holding the distributor and re-check the timing (to make sure you didn't move the distributor by accident) - if you have a vacuum advance can on the disty you typically remove the hose and plug it before timing the vehicle -
That's about it - what it does is ensure that the spark plug fires at the correct moment in time to ensure the best burn of the fuel in the combustion chamber - if it's retarded (happening to late - not acting dumb) you'll get lousy performance and poor mileage - if it's advanced you'll get detonation - if it's WAY off the car won't start -
Steve
(next lesson we can discuss setting the gap and dwell on your new distributor points!)
Old 21-04-06
SAABurban's Avatar
SAABurban SAABurban is offline
I love the fuel econ on my 93'. She is getting consistantly, 31-33 mpg. Fixing the leaky fuel bib with all of it's cracks has really made the difference.
Oh yeah, keeping the steel toe's from becoming wedged at the knee bolsters also worked wonders
