| Classic Saab 900 Performance, Mods & Tuning Covers Tuning & Performance modifications for the Classic Saab 900 |
Here's my situation, my 88 SPG has a autronic ecu with a MSD DIS-2 direct ignition. Unfortunantly the MSD is to powerfull for my saab tach thus above 4K or so it freaks out & goes dead. So I need to add something else to the car & I have no clue what to do or where to put the $#%ing thing. Any suggestions/pics?
1988 SPG 2000 Viggen 1999 YZ 400F 2006 Harley Ultra Classic |
| Sponsored Links | ||
Advertisement | ||
which autronic are you using?
on the sm4 theres a tacho output that you can plug upto where the ignition amplifier used to be - have you tried this? otherwise id leave a post to rayhall on the autronic forum |
I have the older SMC
That's a good idea to throw Ray Hall a question, totally forgot about that & I purchased it from him
we tried a handfull of different resistors with no luck
then tried the MSD parts which caused the ECU to not work at all I just talked with someone who deals in autronic ECU's & he stated there is a autronic resistor that might work, I didn't know there was such a thing. So he's going to try to find it & stated that this should do the trick. fingers, arms & legs are crossed
Aside from that you could just put in one of those big 5 inch tachs. Some places also sell small 2 1/16" tachs. I'd be interested in knowing if that resistor actually works. Keep us posted.
R.I.P. Boosted shoe. (might yet keep the body) Under construction 95 900 SE black on black. |
Normally the tach is driven by the ignition module. Pin 7 IIRC? Couldn't you find a way to re-connect the ignition module so it drives your tach? Maybe you could feed the signal from your autronic through the ignition module? Into Pin 1 maybe?
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
