Saab 9000 Kill Switch - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9000 > 9000 Workshop
9000 Workshop 9000 (1985-1998) Technical Forum
Old 11th April 2006
ellisd ellisd is offline
My Saabs: 9000 CARLSSON 2 LTR TURBO
Default Saab 9000 Kill Switch
I have a 1990 saab 9000 Carlsson (2 litre turbo), i am wanting to fit an ignition kill switch. I want to fit a single switch to a wire going to the red apc/di box under the passenger's seat (no relays or anything), and want the starter motor to still work but not for the DI cassette to fire. Can anyone help please?
Old 11th April 2006
boxman boxman is offline
My Saabs: -
you would be better off going into the back of the relay for the fuel pump and cutting one of the thin wires to that, this will have the double affect of inhibiting the pump and the spark
welcome to saab central
Old 11th April 2006
i thought of that but the main reason for installing the switch is that i'm fitting nitrous oxide and i need to be able to turn the engine over without it firing up (as if the DI cassette was unplugged) to make sure there is no nitrous in the cylinders on startup. If i put a switch on the fuel pump the car will actually start wont it? even if only for a few seconds
Old 11th April 2006
Stefano's Avatar
Stefano Stefano is offline
Saab Mad
My Saabs: 2 9ks,white '87T &'96 Silver Aero 2.0
If the fuel pump doesn't run, you don't get any spark. I know it sounds odd, but that's the way Saabs work
Old 11th April 2006
My Saabs: -
the fuel pump relay also powers the di cassette, so cutting the power to the pump also cuts the power to the di cassette
Old 11th April 2006
OK thanks alot for your help everyone
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
