Drivers Seat Broken - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9000 > Saab 9000 Workshop
Saab 9000 Workshop Saab 9000 (1985-1998) Technical Forum
Old 06-04-06
werewolf werewolf is offline
My Saabs: 9000cse 2.0 eco turbo 1995
Default Drivers Seat Broken
Hi Guys, I have an issue with the Drivers seat in my 9000cse. It has kind of collapsed on one side and doesn't move up and down properly. The reclining part is fine and the sliding from front to back is also ok. Its just the height adjustment that is broken. It will go up and down but if you sit in it, it is twisted and doesn't hold it position.
Has anybody had a similar experience? Any suggestions on what I may be able to do would be great. Also what is the Screwdriver BIT I need to remove the star type screws to remove the seat on its rails.
Look forward to your replies.
Thanks
Old 06-04-06
shortlid's Avatar
shortlid shortlid is offline
My Saabs: 2001 9-5 base, 5-speed manual , 220,000
Question Mine squeaks
The drivers seat in my '95 Aero squeks when I move or go over a large bump. I think somone on the board sugested I just tighten the LARGE Torx screws that hold the track down. Have you checked to see if the track was screwed down?
Please help me take my 2001 9-5 Base 2.3 lpt, 5-speed with 220k on the clock to 300k!!
Old 06-04-06
Yeah. In fact I couldn't get them out!
I think it is more the Hydrolics of the seat that are busted. I wonder if best solution is to try and find a matching seat from another Saab.
Old 06-04-06
shortlid's Avatar
Maybe your best bet, I am thinking if the screws are not in the tracks are not straight and that is binding the power seat!
Old 06-04-06
SaabFEVER SaabFEVER is offline
My Saabs: saab 9000 cs, 1991 BMW 325i
man good thing my seats are manually operated.
Old 07-04-06
Mine are manually operated to. Only electrics are the heated seat element.
Old 08-04-06
vnv727's Avatar
vnv727 vnv727 is offline
My Saabs: Gone: 1994 Saab 9000 CSE 2.3T
im having a similar problem with my passenger seat, only difference is my reclining is the thing that is messed up
anyway i made a post about this a while ago and boxman, i believe it was him, said that its kinda a common problems, apparently i was supposed to look under the seat and see if a wire fell out and to reconncect it unfortunetly for me i can get down there to look at it because my rear passenger door wont open because it is stuck in the lock position and that lock fob thing is able to be lifted up and down but it doesnt feel connected to anything, come to think of it how can i take the door panels off without opening up the door(an impossibilty at this point and thus the problem) please help me if ya know
