switchingT-25 to td-04 - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9000 > Saab 9000 Workshop
Saab 9000 Workshop Saab 9000 (1985-1998) Technical Forum
Old 04-04-06
Saab9000jy Saab9000jy is offline
My Saabs: 91'9000T,94'9000AERO,95'9000CS,989000CSE
Default switchingT-25 to td-04
My turbo on my 91' 9000 has been smoking pretty bad at idle and I figure it's time for a new one. I can get a td-04 for the same price as a t-25 but my question is what else do I need to make the switch? Is the exhaust manifold the same? Oil lines? Exhaust down pipe? Thanks
Old 04-04-06
Last_straw's Avatar
Last_straw Last_straw is offline
My Saabs: '92 9000 2.3T CD, '95 9000 Aero
The manifold and downpipe are the same, I think, but you need to change the oil and water lines plus the actuator and to get the benefit out of it you need an aero ECU or a remap.
Old 04-04-06
Where can I get oil and water lines from? Can I just make some up with materials at the local auto store? My ecu is chipped with the saab performance fuel eprom and apc upgrade. I contacted them and they claim this configuration will work better with the td-04.
Old 05-04-06
Marrk's Avatar
Marrk Marrk is offline
Oil and water lines should be a straight swap, and as you have already mentioned the chips will work okay, in fact the standard APC will work as well.
Old 05-04-06
boxman's Avatar
boxman boxman is offline
My Saabs: 9-3 SS Aero TTiD + 9-3 SV Aero
the bango fittings on the td04 are smaller than the t25 so you will need to replace the lines
sorry marrk
Old 05-04-06
Marrk's Avatar
My bad memory! Keeping you on yor toes!
Reminder, Abbott, pads!
Old 05-04-06
boxman's Avatar
couldnt get an answer on the phone so i've emailed them i'll try again tomorrow if they havent replied to the email
Old 05-04-06
Thanks for all the info. So I need 4 lines, 2 coolent and 2 oil. Does anyone know the size's of lines I need? Like how long and what size ends? thanks
Old 09-04-06
Anyone know the size of the oil and coolent lines for a td-04 turbo??? Or where I could find out??
