temperature sender - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9000 > 9000 Workshop
9000 Workshop 9000 (1985-1998) Technical Forum
Old 3rd April 2006
screamingreen97 screamingreen97 is offline
My Saabs: 97 900se
Default temperature sender
broke the temp sender...umm...there is 2 on eeuroparts.com....which one do i get? the 30 dollar one or the 17 dollar one? mine is a 97 cs....which one is it?
Old 3rd April 2006
9000freak's Avatar
9000freak 9000freak is offline
My Saabs: 1995 Saab 9000 CSE 2.3FPT Manual 180k
Put a link up
Old 4th April 2006
djtaylor djtaylor is offline
My Saabs: 9000 Aero
Do you mean you broke off the little nipple bit that goes in the head? If so, all I did when I did the same was to drill a small hole in the brass end and then solder in a bit of wire onto which I attached a normal spade terminal.
David.
Old 4th April 2006
My Saabs: 97 900se
this one?
http://www.eeuroparts.com/productdet...ts=1&code=6292
or this one?>
http://www.eeuroparts.com/productdet...ts=1&code=6293
Old 4th April 2006
Stefano's Avatar
Stefano Stefano is offline
Saab Mad
My Saabs: 2 9ks,white '87T &'96 Silver Aero 2.0
It depends on your engine number, which depends on when your car was manifactured (before or after mid '97). I guess the easiest thing is to read the code on the old sensor, since I can't tell where the engine number is.
Coolant temperature sender(sensor) for any mid '97(from engine #V002172)-98 900 or 9000, and 99 9-3 models(exc Viggen). If you can't find your engine #, the correct p/n is located on the side of the head of the sensor. Genuine Saab.
Old 4th April 2006
My Saabs: 97 900se
grr...my sensor is on the block still, so i cant take it out yet and im in school so i cant even try to take it out noww....oh well...i guess ill take my chances
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
