Coolant pressure cap slight hiss? - SaabCentral Forums
Old 24th March 2006
ernzo2's Avatar
ernzo2 ernzo2 is offline
Default Coolant pressure cap slight hiss?
My coolant pressure cap makes a slight hiss when the car is hot, but shut down. I notice it when I am under the bonnet for some reason.
If I squeeze the hose, I hear air escaping. The cap looks fine, but I am assuming that it is NOT supposed to ever hiss. I am not leaking coolant, there are no other signs that I am aware of, except...she runs hot.
Time for a new cap? I would think so, but I am just checking if anyone has the same deal, or knows the answer before I plunk down the $.
regards,
erns
Ernzo
  • 87 T16 Rag Top
Old 24th March 2006
16saabs 16saabs is offline
My Saabs: 2x LPT convertible's, 1 x 900 SE
sounds like there is too much pressure being created, eg running hot?. probably needs a good flushing of the system as the rad might be blocked and/or the thermostat could be stuck shut, its just like us normal pressure it can cope with, but excess pressure its the safety valve releasing the pressure, eg we cuss etc when hot and bothered?
Old 24th March 2006
trackside trackside is offline
Perfectly normal for the cap to leak or hiss slightly - there is a pressure relief valve in there. If the engine is running hot all the time you should investigate; thermostat, radiator, ignition timing, mixture etc.
Old 6th April 2006
Matthew's Avatar
Matthew Matthew is offline
Saab Mad
My Saabs: 900 S Aero Turbo, 9-5 Aero
I'm more concerned with the hot running.
Antifreeze contains an additive which raises the boiling point of the water. If the coolant's old (you should change it at least every two years) then it may be boiling, causing excess pressure. That pressure will be vented through the cap. Unfortunately, that release of pressure lower the water's boiling point some more (water under pressure has a higher boiling point).
Is the radiator original? When was the thermostat last changed?
Read this:
http://townsendimports.com/Web/cooli...coolingsys.htm
On the other hand, the expansion tank's cap may be faulty and leaking. When that happens, the coolant boils and excessive pressure will build up in the cooling system. I had that on my 900, and a replacement cap solved the problem.
However, you should thoroughly inspect and, if necessary, service the cooling system.
Old 6th April 2006
woolf's Avatar
woolf woolf is offline
My Saabs: '91 900S Aero X-LPT
Are you sure it's not something simple like a leaking pressure cap?
Are the radiator hoses getting very firm with pressure, or is the hiss evident when there's not much pressure in the system?
"Don't be breaking your shin on stools that aren't in your way!"
Old 6th April 2006
kemosaabey kemosaabey is offline
My Saabs: MB 190E ex 9000i 900i 900GLi T16Sx2 99x3
You might have a light h/g leak over-pressurising the coolant - but more than likely it's just a dodgy cap..
Old 6th April 2006
Shan's Avatar
Shan Shan is offline
My Saabs: 9000, c900, 96 V4 & stroker
You mentioned that the hissing occurs when the car is hot, but shut down. When the engine is no longer running, the coolant cools down and contracts. In order not to cause an underpressure in the system, the vent valve in the cap allows air to enter the system as the coolant contracts and may cause the hissing sound, but check if there is any obvious leaks or loss of coolant.
Old 6th April 2006
Matthew's Avatar
Saab Mad
The coolant does cool, but not before its temperature has risen due to no radiator effect.
Old 6th April 2006
900t's Avatar
900t 900t is offline
Saabista
The ethylene glycol doesn't break down in and of itself. The boiling point of the coolant should remain relatively constant. In fact it should rise as crud in the engine is suspended in the coolant, thus reducing it's vapour pressure
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
