ABS Issue Quick Resolution
My 2009 9-3 2.0T w/6 speed manual transmission had been a very reliable car until it reached 130,000 miles last month. Almost immediately upon reaching that milestone the dreaded ABS, Traction Control and Stability Failure errors appeared. I also noticed that the odometer stopped working, although the speedometer continued to function properly, and the steering wheel lock failed to operate and remained in the unlocked position.
On this car the ABS electronics module is positioned approximately one half inch (13 mm) from the left side strut tower. I cut a section of automotive heater hose to a length of 11/16 of an inch (17mm) and wedged it between the ABS electronics module and the strut tower. I positioned it roughly in the center of the electronic module cover effectively exerting pressure on the module. To my surprise the warnings and associated problems disappeared.
I don’t know why this works.
I don’t know how long it will work.
I don’t know if it will work on other cars.
As of this posting I have driven in excess of 750 miles without any trouble. Go figure.
