| Classic Saab 900 Performance, Mods & Tuning Covers Tuning & Performance modifications for the Classic Saab 900 |
I've been digging for info on the triumph V8 and i found something on a Fin (Fin'ish?) site (I think
Cheers http://www.saabclub.fi/phpBB2/viewto...cdd81506fad6a1
Psytuned 1997 900 Sensonic coupe turbo |
| Sponsored Links | ||
Advertisement | ||
You can get a gist from online translators:
First paragraph: Quote:
Photo Gallery |
I was wondering whether you could put Saab heads on the block, i guess one would be the wrong way around though
some where in my book case i have a book that talks about saab experimenting with a V8 99 useing the stag engine, but plans were dropped as saab thought the nose weight was too high and the handling was upset so it didnt drive all that well, saab went the turbo rout instead
Nope, those engines have the funny wonky head bolts (the often recommended method of removing the head is to smash it to pieces
The early 1709cc heads probably fit - and maybe even the Dolly sprint heads. But not a Saab B head and defintiely not an H.
Photo Gallery |
One 1709 head, or one Sprint head would fit the left-hand cylinder bank of the Stag block. A head for the right-hand cylinder bank would need to be cast in "mirror-reverse".
Without wishing to sound biased, but isn't the Truimph V8 supposed to be rubbish?
If you want to do a V8 concversion I would have thought a Rover V8 would have been a better bet as there is much better support for them in terms of parts and tuning (RPi engineering being one them). Of course that said I don't know if you could cram a Rover V8 in there
TJ's Saab 99 Gallery 1 |2| The Digital Saab 99 Aint nothin' in the world as fine, as driving in my ninety-nine... |
you can fit a chevy 454 in there so why not a 4lt rover v8
SAAB: Its an Addiction |
I was really more interested in parts compatibility, using saab pistons, maybe timing gear, so rather than a straight swap it would be some kind of Saab/triumph hybrid
But i suppose a RWD 3 or 4 litre twin blower 900V8 would be an interesting site
But they're still not a decent replacement for a Saab engine.
Photo Gallery |
sorry, I've only just found this thread!
I never got round to comparing a v8 to a saab gearbox! I'm not sure if the v8 would fit under a saab bonnet though. Theres a fair bit of height to a v8 - little things like the air intakes/carbs and the dissy stick up quite high above the rocker covers. realistically, fitting a later 16v saab engine gives the same sort of power as a rover v8 and is much less hassle! A year or two back i did find a classified ad for someone selling a RWD v8 powered saab 99. I cant find it now though |
Aha! Something i know about! The Triumph stag V8 is quite literally two TR7 (and early saab 99, the 1.X liter ones with the skinny valve cover) engines stuck together. As such, the left hand head is the TR7/saab head, while the right head is a stag-only unit. Because of the V setup, you can't just plop the left head on the right side, the exhaust ports would be where the intakes are supposed to be and the head bolts (angled, dumb design) would have the head at a 50 degree angle to the block. If you rotated the head to fix the above problems you end up with the front of the head, with the timing chain sprocket, at the rear of the block, not so good. Someone did some research a while ago about trying to put Sprint 16v heads on it, but found that and gave up. If you have a good cooling system, and if/when it blows a head gasket you stop driving imedietly (rather then trying to make it to whatever), they are decently long lived. They don't have any more problems then the early saab 99's reliability wise. They do weigh a lot though.
--Bobnova '89 Honda Prelude 2.0SI 4ws '76 Triumph TR7 FHC, hopefully soon with supercharged saab '79 900t motor. (Note: I have no saab specific knowlage, but have been working in a shop since i was six |
So what would be the chances of Saab turbo pistons fitting into a Triumph V8 block?
due to the Trimuph engines over heating problems are you just asking for trouble. I'd only undertake something like this if i could twin turbo it, else there's no real point as you can make good power with a blown 2l engine. I could fab up the headers and intake pipes myself, just would'nt want to get too bogged down in remanufacturing engine parts.
Si you just want to claim a mountain cos its there
OK so what about a rangie V8, box and AWD, into a Saab?
Anyone done that before? Just think of the difference in wheel size combined with the difference in weight
[QUOTE=Si]OK so what about a rangie V8, box and AWD, into a Saab?
[QUOTE] Have you seen how big a rangie box is? You aint putting that in the front of the car unless you want to make a very big transmission tunnel!. My landrover 101 has a rangie engine and box in and that uses a special shorter bell housing to make it fit - and its still huge!. If you are serious about doing the RR engine and box, Jambo (sorry Jamie! |
He just offered it, yes i have got space, although i don't think the neigbours will appreciate it! Would have to strip it and get the shell collected relevitely quickly.
I'd probably strip the Saab (try and pick up another 2 door carb or injection) right down then cut all the nessesay bits out and just weld in a tube frame to stiffen the shell. Who could say no to an AWD 4l V8 900?
I had a TR7 with a V8, but it was a Monza V8 conversion, not a Triumph engine. Went like stink.
Ive always thought with the new link between subaru and saab that a scooby "boxer" engine and 4wd system would be a fun upgrade for a 900! lot of power potential there!
nONONONONONONONONON TWIN TURBO v8
As you can get supercharged rover V8's i figured it would'nt be to hard to swap psitons and twinturb it, Not sure about the ratio's on Rangies 4*4 though so may have to mess with that and the primary gearing as the engine would be shifting a tonne or so less weight about.
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
