| The Lounge For Saab related posts of a non-technical nature |
I am building a new home in the spring, complete with a 36x24 foot garage.
My biggest question is the upfront cost vs. the long term pay-off. Lots of information on the net about long term benefits, not much about short term expense. What about reliability? Soon to be broke- SD
If always did it right the first time, how would I learn anything? |
| Sponsored Links | ||
Advertisement | ||
I may be wrong on this, but hasn't your current head of state done this at there ranch?
1998 Saab 900se 2.0 Turbo Convertible 1999 Saab 9-5 se Waggon 2.0 Abbot Racing ecu 1997 Saab 9000 cse 2.3 stg 3 (mothballed 1997 Fiat Punto 1.25 85hp |
Installed geothermal or gone broke? It would be the 1st I've heard of geo at his Crawford place, but if he did I'd bet he got a good deal
SD
Are you refering to a heat pump or do you have a hot spring in the back yard?
If it is a heat pump, I would use solar cells to drive a heat pump, with a bank of batteries, as most heat is used when the sun is down. Then you have choices of whether to use a well (vertical) or a leaching field for the expansion, heat exchanger. Or a combination. If you're from the mid west, I would also get an automatic feed, corn furnace. Grow you own fuel. Cheaper than pellets, and you can pop it if you're ever hungry.
"A fax is a little animal that eats chickens. Half of them are male and the other half email" Bullwinkle Moose!
Much of this depends on your soil conditions, water table and quality, climate and availability of fuels..
The future is what you should design for, and that is sophisticated computer controls, some, or a lot of solar gain and modern fuels such as corn , wood, even coal...and of course, geo-thermal... Note - no dino fuels. The time will come, maybe within 20 years that oil can no long be burned... Maybe natural gas in certain areas... Then you should employ the service of a good HVAC engineer to design the system. Assure that he possesses intelligence and is forward thinking.. I hold that a man could "almost heat a house with a candle", but that the cost could be too high !
The earthworm '96 900S, Automatic Those who think in the past will have no future. 173K miles in the good ole USA Last edited by earthworm; 06-02-06 at 08:57 PM. Reason: Forgot to use spell check. |
Thanks for the input! SD
I'm looking at a solar heat exhchanger for hot water, there's a fair bit on the net, it's kinda like putting a black radiator on your roof then pumping water between it and your hot water tank.
Psytuned 1997 900 Sensonic coupe turbo |
I'd love to do this...
solar century If all the south facing facades and roofs in the UK were covered with such product then during the day we'd not need power stations, can you imagine that? idling Sizewell until nighttime and bye-bye Drax! The collapse of the energy making sector, bankrupt Mr Burns
My parents have just had a house built using under floor heating and a heat exhange pump with more pipe buried outside. The heat pump comes from Sweden
I've put in some underfloor heating, under marble floor tiles as it happens, I can recommend this.
SD
I suggest two publications. Home Power magazine and Backwoods Home magazine. BWH has a bit more survivalist approach, but it is still quality and loaded w/ info. You may try Mother Earth News but it is a bit preachy.
As far as pellet stoves go, I have heard mixed things. I know someone locally who has one who says that it sucks. They say the heat is not very satisfying. Others rave about them. I think Dirk and Ashli have one (Diggler and Rollergirl). You may ask them. I really spent a lot of time looking into this and solar after Katrina and Rita. But it's just too cost prohibitive for me at the moment. People spend upwards of $15k on these systems and they require a bit of investment in time as well. I've read planty about people who thought they spent plenty on perfect systems only to spend quite a bit of time running off a diesel generator. I sincerely HOPE it gets off the ground though. Of course, w/o the high cost of oil, we'd be furthur up...uh...a creek here in Louisiana. |
This is a great thread, i was thinking about building an under ground bunker/room and this was going to one of the big problems, a renewable stable long term low servicing power supply, i thought wind power was a good option but solar cells are probably the best all round.
Do you plan on storing your power in the forum in batteries or heat? |
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
