DI cassette change - SaabCentral Forums
Old 1st February 2006
Daysleeper Daysleeper is offline
My Saabs: 95 2.0 lpt
Default DI cassette change
Hey all , am I right in thinking I can just swap out the DI cassette?
I'm running a 1998 '95 2.0 lpt with a few problems which I think relate to the DI. I've got access to a crashed 2003 with a working DI so the question is can I just switch in the 03 one? Its marked TK3 4D C and has a sticker saying "warning only resistor spark plugs permitted"
jedi_master58's Avatar
jedi_master58 jedi_master58 is offline
Location: Toronto, Ontario, Canada - 2007 Saab 9-3SS 2.0T, 1999 Saab 9-5 lpt
My Saabs: 2007 Saab 9-3SS 2.0T 4cyl
Yeah that should be fine. The "R" means the spark plug has to be the R type NGK. As long as the DI Cassette is for a T7 and if its coming out of a crashed 9-5 then you should be fine but it does not hurt to double check. Change the spark plugs as well. A failing DI Cassette can melt the plugs. Make sure you use NGK BCPR6ES plugs. Changing the DI is a cake walk, just unscrew it, disconnect the wire and connect the new one.
Good luck!
thanks for the speedy response Jedi.
As long as the DI Cassette is for a T7 ....but it does not hurt to double check
Any way to double check? Based on serial number etc?
Not a problem Sleeper lol. You can ask the person your getting it from. It is coming from a 9-5 and it's the black DI right? If so you should be safe. Is you Check Engine light on by any chance?
i want an aero's Avatar
i want an aero i want an aero is offline
My Saabs: 1998 95 2.3 lpt se nordic tuning
you can get a new 1 with 2 year guarentee for 100. so why buy second hand only to replace later on
Chris 9-5's Avatar
Saab Sage!
My Saabs: .
If its out of a 2003 car its the correct part
Check engine light is not on, car is staggering, occasionally wont start, under high revs it wont accel just very jerky. Thought I'd start with the sparks and DI. If this dont cure it then CPS next.....
Where? PFS cheapest is 140 inc delivery.
Besides I'm not sure it is the DI, so by swapping out for a cheap alternate if the problem ceases then I can buy a new one having narrowed it down to that component. If not then I have not spent large sums on a blind alleyway.
Have pulled my DI and Sparks, which are not in great condition. Big gaps hmmm
Chris 9-5's Avatar
Saab Sage!
My Saabs: .
The gaps are fairly big at 1.1mm but it has been suggested that too wide a gap or too small a gap can add to the DI failure rate.
Any other decent stuff on the 2003?
turners hill sabb 110.85 delivered. bought 1 for myself just after nordic upgrade
Without giving too much away, its still awaiting an insurance assessment......as the front end had nothing to do with it being trashed its kind of a "borrow" the DI on the weekend to check if it cures my problem and pop it back in by monday morning....
Why don't these people advertise, I've been googling DIs all evening and they never came up. Thanks I'll check em out.
01342 718799 parts dept direct line
Old 2nd February 2006
Just a quick thanks for all your help on this guys, I swapped the DIs over this afternoon, just done a quick 10 mile test drive and no problems....no judder etc etc. Think thats that one nailed down, on to the next challenge (problem)
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
