SQR Stage 4 - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9000 > Saab 9000 Performance, Mods & Tuning
Saab 9000 Performance, Mods & Tuning Covers Tuning & Performance modifications for the Saab 9000
Old 01-02-03
GRD GRD is offline
Default SQR Stage 4
I installed the SQR Stage 4 yesterday. This setup really turns the AREO into a high powered sports sedan. I was really impressed after the programming runs. I blew my new BOV within 30 minutes. You could hear it leaking and then PPPFFFSSSST. No more boost above 15psi. I put the original one back in and things are fine, other than hearing it leaking.
SQR really does a good job with their programming. Knowing they build Saab motorsport racing motors gave me confidence. The car really flies. Amazing performance.
Ordering a better BOV, then to the dyno to see how much power the setup is making.
Fun sleeper sedan.
George
Old 15-02-03
pieceofsaab pieceofsaab is offline
where'd you get this kit? Got a link?
Old 15-02-03
BillJ BillJ is offline
My Saabs: Error 404
Default Re: SQR Stage 4
If it's the latest type that Saab sells (with a weight attached to the diaphragm), then I blew a brand new one in less than 3 days (don't know quite when it failed). I refitted the previous one (a Bosch one of the previous type) and all worked fine. Fitted a Bailey valve a while later and it failed after 4 months (it wasn't new to begin with, though). Back to the trusty Bosch valve - problem fixed (again). I'll try again with a new Forge valve, I think, as I really want a quick-acting valve for the sort of boost I'm running. Hope it lasts...
Old 23-02-03
Friberg Friberg is offline
We've just had a discussion on STCS's forum about which valve to use for high boost and the most common one used among the high-boosters in Sweden seems to be the stock Mitsubishi EVO6 BOV.
But there are also o few still going with the old Bosch one, but with the connections turned the other way around.
One of the high-boosters blew a new Forge valve - so maybe you should try the EVO 6 instead, and save a few £ :wink:
Old 23-02-03
My Saabs: Error 404
Too late - I've already bought the Forge. Not fitted it yet. How much was the "high booster" boosting? I'm only boosting to 1.6 bar.
Old 23-02-03
Some of them are boosting 1.9 bar The guy who blew his Forge I don't know...
