How to remove a Front Bumper? - SaabCentral Forums
Old 19th January 2006
MrB MrB is offline
My Saabs: '03 9-3 Aero
Default How to remove a Front Bumper?
Hey guys, Im picking up my Aero '04 bumper tomorow. I think I will have a go at changing it my self, as its just a direct replacement. Does anyone have any previous knowledge of how its done? where are the screws loacted, do the wheels need to come off etc etc....
Thanks
Old 20th January 2006
MrB MrB is offline
anyone?
nikme411 nikme411 is offline
Don't know the answer, but maybe someone will add to the thread if I start you off at the front wheel arches where the bumper is screwed together to the inner wheel arch lining...
XAAMOTTOMAAX XAAMOTTOMAAX is offline
My Saabs: 2003 9-5 Aero
Default from WIS....
open hood
raise the car
remove center grille (lift slightly to loosen bottom, pull forward and down so the spring clips loosen)
remove side grilles by bending up the lower clips so they loosen and lifting
remove battery cover
remove turn signals
remove headlights
remove the screws holding the bumper shell to the bumper member (looks like 3 screws on each side of the grill)
remove the washer nozzles by pressing in the clips on both sides with 2 small chisels (press the clip down so it releases and the nozzle can be removed, check that the clip locks correctly...if not use a new clip)
remove the screws holding the bumper shell to the fender liners (dont remove the liners though)
remove the spoiler shield (skid plate)
remove the 5 circular clips above the grill portion of the bumper cover
unplug the fog light connectors and the temperature sensor connector if fitted
first loosen the outer corners of both sides of the bumper so that they release from the fender liners
loosen the bumper from the side and pull out the 6 tabs from the attachments
remove bumper shell
GOOD LUCK!
gto47
Guest
Posts: n/a
For 02-05. Can post the rest of the part numbers if you need them.
Old 21st January 2006
timmehhhhhh's Avatar
timmehhhhhh timmehhhhhh is offline
My Saabs: 02 9-5 | 06 9-7x | 04 9-3 no more =(
Straying off the topic only a little bit...you know the 2001 and older headlights will not fit with that bumper right?
95 AERO HOT 95 AERO HOT is offline
My Saabs: 00 9-5 AERO EstateX2, 9-3 Aero 2.8 Vert
Straying off another bit, are you selling the old headlights, foglights and drivers side indicator?
Chris 9-5's Avatar
Saab Sage!
My Saabs: .
He is not changing the headlights or sidelights
And of course if anything were to be for sale it would be in the Saab Central classifieds......have a look
Didn't know that you could fit the new bumper with the old lights
StX221's Avatar
StX221 StX221 is offline
My Saabs: '02 9-5 Aero
the headlights will fit the new style bumper. but the metal bumper (not the outer skin) needs to have the old headlight wiper mounting tabs removed to make the new style bumper cover fit properly.
Nick
2002 9-5 Aero
Chris 9-5's Avatar
Saab Sage!
My Saabs: .
MrB is changing his "new style" facelift front bumper for the aero "new style" facelift front bumper, he does not have the old style, ie pre MY2002 car
StX221's Avatar
ooops. sorry boys, thats my fault
2002 9-5 Aero
MrB MrB is offline
Hey guys, thanks for the reply's and the step by step instructions. I think I will have a go, doesnt seem to complicated. Was going to get it done from Weston (chris's friend) but he's just to far from me. Time to bring out the Tool kit me thinks
Chris 9-5's Avatar
Saab Sage!
My Saabs: .
MrB would you do a step by step photo guide please
MrB MrB is offline
Okie dokie, will do. Pics wont be that good tho, will have to use my Camera phone.
Old 22nd January 2006
Awww....I wanted to sell him my OEM Xenon headlights
THRough the classifieds section of course!
Chris 9-5's Avatar
Saab Sage!
My Saabs: .
Try it anyway Say its an Abbott upgrade
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
