Finally picked up my 85 T16!! Few boost questions. - SaabCentral Forums
Old 24-12-05
jonboy545's Avatar
jonboy545 jonboy545 is offline
My Saabs: 1985 900 16V Turbo
Default Finally picked up my 85 T16!! Few boost questions.
Well, the previous owner told me he's been putting 87 in the car, so when I first drove it, was a good way to "test" the APC...
Now I'm not exactly sure on the workings of the APC, but it went a little bit like this.
Accelerating in 3rd gear, the boost would kick in, midway in yellow, then die down a little bit... just felt like it was dropping a tad bit, then maybe later on it would kick back in. By 4500-5000 the boost would drop off. I can assume this is just because its having a hard time breathing with a 100 percent stock intake and a old dirty cat. converter.
So I basicly emptied the tank out (ran until the light came on) then filled it with BP 93+.
Well, didn't change the boost at all. Now, (and even before) it seems to hesitate slightly under boost at WOT. Just like chugging. Engine runs very smooth, but momentary split second dips in power.
I have yet to do a tune up, and this may cure my problem... but maybe this is a common problem..
Doing plugs, distributor cap and rotor button, and will do wires in 2 weeks. Also changing air filter, and oil/filter change.
If it doesn't go away after this, then I can further diagnose it.
Seems like the car is slower than my bone stock (except gutted catalytic converter) 4 door 8V N/A!!! Now 4th and 5th are definately faster in the T16 thanks to the boost, but 2nd and 3rd seem slower than my N/A.
We'll see after the tune up!
Just for the heck of it... here's some pics of my new baby!
http://www.rallyboy.com/index.php?mo...wgall&gid=8&p=
Old 24-12-05
Basre Basre is offline
Banned
Congrats.. Now that you have the Car.. Start looking at the Wiring Harness 85's hads the dissoilving wiring Insulation problem. There are Few survivors.
Check ALL wires anywhere there is heat: engine compartment and ignition switch area (catalyticheats this area) FIX any you find.. immediately.
No waiting!
On your boost issue, Base boost (fail safe mode) is middle of yellow (8 ish psi), with a healthy OEM engine /system you should be boosting to space between yellow and red on your dash gauge... about 10/11 psi
Bentley or Townsend Site has a comprehensive Boost diagnosis procedure.. Follow it , to the Letter.. It works !
Old 24-12-05
nutcase's Avatar
nutcase nutcase is offline
My Saabs: 1978 99T in black; 1983 99GL in Beige
A quick note on your plug wires - are they bougiecords? If so, don't change them unless you definitely find a problem. They are extremely good leads and are hard to beat.
Old 24-12-05
ShadowWorks's Avatar
ShadowWorks ShadowWorks is offline
Banned
My Saabs: The Black Night, 900T
This may help
After years of poodling around some cars gets gummy and stiff, they basically need a good long thrash on a free way, years of slow driving can makes engines sticky, so maybe all you need is a good long drive
Old 24-12-05
jonboy545's Avatar
No, unfortunately... they are cheap o advance auto wires... I however will be changing them with bougiecords from saabsite.com
Old 24-12-05
jonboy545's Avatar
No waiting!
Oh great... that's good news
I guess I can start that inspection today. Merry Christmas
Now, last night after a good LONG drive with alot of boosting with the new premium fuel... the manifold and turbo were glowing!!! Now I've seen modified turbocharged cars do this, but not a stock turbocharged car. This leads me to believe that maybe the catalytic converter is clogged a bit?
Old 24-12-05
900t's Avatar
900t 900t is online now
Saabista
Nah a hard driven 900 turbo will do that.
Old 24-12-05
DeLorean DeLorean is offline
you can get it glowing to red at night running it up to maximum speed, the entire manifold and turbo will glow BRIGHT red, even the downpipe will glow red too.
this is typical of any stock turbo car.
Old 24-12-05
jonboy545's Avatar
Hehe...
sure does, another night of hard driving, and man o man was that puppy glowing!!!!
I was trying to see if my cat was clogged, if it was glowing as well, then it was more than likely clogged... down pip was red, but it faded before it got to the cat...
I think I have a fuel problem... replacing the filter soon... Also installing a knock LED
See this thread for details:
http://www.saabcentral.com/forums/sh...ght=hesitation
(my post is at the bottom)
Old 27-12-05
Matthew's Avatar
Matthew Matthew is offline
Saab Mad
My Saabs: 900 S Aero Turbo, 9-5 Aero
Base boost is around 5PSI, not 8.
A stock T16 will have a glowing manifold when it's run for a long period at high speed, but you should inspect the catalytic converter too. You don't know that the cat isn't contributing to the glowing manifold and poor performance.
The path of my life is strewn with cowpats from the devil's own satanic herd
