axle boots - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9000 > Saab 9000 Workshop
Saab 9000 Workshop Saab 9000 (1985-1998) Technical Forum
Old 27-11-05
screamingreen97 screamingreen97 is offline
My Saabs: 97 900se
Default axle boots
i axle boots are shot, but the axles dont seem to be making any sounds like my mechanic said it would...i baught the boots for a non turbo for 14.99 a peice...can i just replace the boots or does the entire axle have to be replaced? if not, how do i replace the boots?
Old 27-11-05
9000freak's Avatar
9000freak 9000freak is offline
My Saabs: 1995 Saab 9000 CSE 2.3FPT Manual 180k
So long as you have not gotton a spec of dirt inside the cv joint, there will be no need to replace the axle. As you said, as long as there is no sound when you turn, you havent harmed the cv joint. The directions are pretty straight forward: http://www.quasimotors.com/cv_boot_replacement.htm
You said that you have purcahsed the boots, however, it will be much better if you purchased the kit that comes with the boot, two hose clamps (one big and one small) and a tube of grease.
Also don't forget an extra tube of grease!!!
Old 27-11-05
Basre Basre is offline
Banned
Hunt up the "Quasi Motors' Site (google) there you will find Photo instruction Follow it and with luck it will be a 3/4 hour adventure per side.
If experienced this could be a 20 min repair. G'luck.
Old 28-11-05
My Saabs: 97 900se
yea, it is the kit, comes with 2 clamps and grease
Old 28-11-05
bluebunny524 bluebunny524 is offline
My Saabs: 1992 9000 Turbo stock
My 92 had 2 torn boots. Who knows how long they were running it with torn boots. Since they weren't knocking I just did the boots. Several 1000miles later they still work great. My only advice is to find BETTER clamps, I like the screw type hose clamps. The clamps that come in the kits suck.
Old 28-11-05
AUSSIE JIM AUSSIE JIM is offline
My Saabs: 92 9000CSTS, 86 9000 AIRFLOW,87 900T
just do boots, carefull when using screw type clamps. don't over tighten and check that the screw bit on the clamp doesn't hit any thing. might look ok when the stub axle is hanging but soon as you drop it on the deck the screw bits can hit and rip the new boot off!!! don't ask me how i know this.
Old 28-11-05
bobbyd's Avatar
bobbyd bobbyd is offline
My Saabs: 1991.9000SE 2.3TURBO.200BHP STAGE 0
. common sense my friend, that's what i lacked when i done the big end with a massive cable tie, clean off ,boot,grease lost,grease all over the place after i came back after a wee test run . ach well, you live and you learn
Old 29-11-05
chris_h chris_h is offline
Default Not easy to get the driveshaft nut off
It might be worth knowing the drive shaft nut is torqued to 210lbft, which is pretty tight. Unless you have a large breaker bar or a pneumatic impact wrench you will find it pretty difficult to get off. You can change the boots without taking this nut off by splitting the CV joint. When you take off the boot there is a large circlip holding the drive shaft in the CV joint, Using a set of circlip pliers just open the circlip and pull the drive shaft out. You nee to undo the 3 small bolts which connect the bottom ball joint to the wish bone first. This then allows you to pull the suspension strut (with the hub and CV joint) away from the drive shaft. It took 20 mins a side to do this. Just for information my boots lasted until 140,000miles before both splitting at the same time.
Old 03-04-06
Matthew's Avatar
Matthew Matthew is offline
Saab Mad
My Saabs: 900 S Aero Turbo, 9-5 Aero
Next weekend I'll be replacing both CV joint boots. 1994 9000 CSE, 195,000 miles.
The inner boots for the tripods appear to be free from visible cracks, but should I replace them anyway? They're not subject to the same degree of movement as the outer boots, but do they tend to need replacement at the same time as the outers?
I'd rather do just the outer CV joints.
The path of my life is strewn with cowpats from the devil's own satanic herd
Old 03-04-06
Marrk's Avatar
Marrk Marrk is offline
Just do the outer, the inner last for the lifetime of the car IMO, however when you pull the driveshaft off, which in my opinion is the best way to do it for accessibility you will find the inner joint either dry or the grease will pour out like liquid. So I recommend replacing the grease on the inner joint while you do the outer ones.
