Stock fuel injector size - SaabCentral Forums
Go Back   SaabCentral Forums > Saab NG900, 1994-1998 and OG9-3, 1999-2002 & '03 Convertible (NG=new gen/OG=old gen) > NG900 & OG9-3 Performance, Mods & Tuning
NG900 & OG9-3 Performance, Mods & Tuning Covers Tuning & Performance modifications for the NG900 (1994 to 1998) & OG9-3 (1999-2002) & '03 Convertible
Old 13th November 2005
rush6432 rush6432 is offline
My Saabs: 1996 900 SE
Default Stock fuel injector size
Anyone know how big the stock 2.0 turbo fuel injectors are in CCs??? 450?? bigger?? smaller??? i need to know so i can calculate out the ammount of boost i can run. also if anyone knows how much the stock fuel pump flows that would also help me out.
Ryan33 Ryan33 is offline
My Saabs: 1999 9-3 Stage 4+
fuel cut is 15.5 with the stock ecu, so you cant run higher then that...
Well theoretically, yes you can run higher than 15 psi, if you wire in a zener diode onto the signal wire and ground wire of the map sensor. Anyway, Still that doesn't tell me the size in CCs of the stock fuel injectors, like the turbocharged eclipse fuel injectors are 450CCs and the 3000GT VR4 Fuel injectors are 360CCs. anyone happen to know what size the turbo saab 2.0 fuel injectors are?
Old 14th November 2005
Anyone know?
hunt.dogshome's Avatar
hunt.dogshome hunt.dogshome is offline
My Saabs: 9-5 Diesel
http://www.members.lycos.co.uk/maxbo...plications.pdf
http://www.max-boost.co.uk/max-boost...basic-info.xls
肉(rņu)包(bāo)子(zi)打(dǎ)狗(gǒu) (meat+bun(2nd and 3rd)+hit+dog)
* Literally: To hit a dog with a meat-bun.:-O
Old 15th November 2005
doesn't really say the size of the injectors for the turbo 2.0 motor. If the 240cc injectors it listed are infact the size of the injectors then i dont see how the engine is alive under 20 psi boost from that small t25.
tidewatersaab tidewatersaab is offline
My Saabs: Silver 97SE 5 Door 2.0 Turbo
i have seen specs that the stock injectors are suppossed to flow 352 ml in one minute. what that is in cc's not sure, maybe the same?????
What The ????
Yes 352 mL (or CC) per minute for NG900 Turbo.
Bosch EV1-3E RED 12 OHMs.
Old 16th November 2005
DrBoost's Avatar
DrBoost DrBoost is offline
My Saabs: 9000 B234R+ M/98 and 9-5 Aero Sedan M/01
Hej !
The Bosch ...431 injectors (red/black T5 Turbo) flows 260.7 C7H16 / minute @ 3bar.
This is about 0.352 l @ minute @ 3 bar.
Is that Heptane? Is that what injectors are calibrated with? Not "gasoline"?
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
