I think I messed up :( - SaabCentral Forums
Old 13-11-05
Saabdriver.lt Saabdriver.lt is offline
New Member
My Saabs: 1995 Saab 900s 2.0i
Default I think I messed up :(
First of all Hello. Now... I was changing the antifreeze on my ng900 today, everything went smooth... until the end, when i broke the plastic off the draining plug!!! I don't know how serious it is to i decided to seek your councel. At least the plug isnt' loose... Anyway, is this a big problem or should I just stop worrying? Thanks in advance
Old 13-11-05
JMarkert's Avatar
JMarkert JMarkert is offline
My Saabs: 2004 9-3 linear
Welcome!
Hmm, I'm not sure. Did you just break the extension part that can take a hose? If so, it's probably fine, but check it often at first to be sure. Many of us have never bothered with this wimpy and hard to find plug - it turns out that it's easier to just remove the lower radiator hose instead.
Old 13-11-05
powellscooter powellscooter is offline
My Saabs: 95 900se
Welcome fellow newbie.. It sounds like you just broke the exterior portion of the drain****, which should be fine as long as it seals, there are no drips right? You can pick up a replacment and change it out later with a minimum of coolant loss when you have the part at hand
82 Mercedes 500 sel (grey market euro) -76 Jeep cj5 (bone stock) ***-89 BMW 735i (should have kept it) -83 BMW 320i (sold) -78 BMW 320i (sold, no a/c in AZ) -74 BMW 2002 (sold) -too many VW oval and split window bugs to count, foolishly sold cause I was young and never thought they`d be valuable
Old 13-11-05
New Member
Thank you for your help. No, there are no leaks, i think i overdone it trying to seal it, that's why it broke of... I just hope that it won't start leaking...
