Rear seat - SaabCentral Forums
Old 06-11-05
SAABotaged900S's Avatar
SAABotaged900S SAABotaged900S is offline
My Saabs: 86 9000 Turbo
Default Rear seat
I know there are no stupid questions, well I'm going to test that theory.
Today I brought my 91 900 Turbo 3 door back home. While going through the car, I was trying to move the rear seat where I could fold it down. The back moves up and down but the bottom part doesn't budge. Is it different than my 87 3 door? How can I get this seat to move (if it moves at all, I imagine it would but I simply don't have enough energy to sit out there and play around with it for any longer )
Thanks in Advance.
Tim
2002 Saab 9-3 SE
2000 Nissan Frontier XE 218k miles
Old 06-11-05
woywitka's Avatar
woywitka woywitka is offline
My Saabs: '87 900 T16 vert, 911 SC,914,W123 Diesel
on cars that are totally worn out you have to grab the little rope thing and tug on it to release teh latch. chances are your banged 900s was just so worn that the latch did nothing. if your talking about the upper part there are two latches with hadels that need ot be grabbed.
Old 06-11-05
cdaly's Avatar
cdaly cdaly is offline
Moderator
My Saabs: '92 900LPT, '90 900i vert
You may have to fish around between the seat back and base in the centre. There should be a latch and strap there...
Old 07-11-05
OK I just came in from trying the backseat thing again, yet once again no suck luck. There is no strap or loop in there. I did find bottlecaps to Old English 800, but no strap. I did feel some kind of piping or tubing and what might be a spring, and I felt around for some kind of catch, but found nothing. Any suggestions?
Tim
2002 Saab 9-3 SE
Old 07-11-05
jefspg jefspg is offline
My Saabs: 88 SPG, 2001 Aero Wagon
To remove the lower seat without the strap, you need to unbolt the seat rail from the seat. It's just a couple of small screws from underneath.
Then you pull and twist the seat untill it unlatches.
