Steering rack brace - SaabCentral Forums
Old 14-01-03
jpgibson jpgibson is offline
Default Steering rack brace
Ive just seen the diy brace on ERP's site.Has anyone done it ? If so ,any tangible difference?
Cheers
Jonathan
Old 14-01-03
Munki Munki is offline
My Saabs: 2004 9-3 2.0T Aero - Vtuner stage 0
I was looking at that earlier...I wonder if it works... :-??
http://www.lehigh.edu/~erp4/saab/Upgrades/SBrace.html
Care to comment Eric?
Old 15-01-03
Default Answering your own post
Things are bad when you have to answer your own posts.
I did the brace today-on the other side to most of you-we are RHD down under.I changed it slightly as I couldnt get the 1/2"->1/4" reducer.I used a 1/2" cap and drilled it, put the 3/8" nut inside and the bolt through the outside.Tightening the cap held the nut .I also used my angle grinder to cut the tube so the end that attaches to the brace was 1/2 the thickness-I didi this as I dont have the means to crush the pipe ( even with a sledge hammer).Anyway it all looks good.
Does it work though?
Does seem to have tightened it up a bit, torque steer has already been reduced since I put on the Saab roadholding kit and Eibach springs.
Worth doing?
Probably, and the bits cost $8 aussie ie $4 us, or 3 quid
Old 15-01-03
ERP's Avatar
ERP ERP is offline
My Saabs: Turbo X 19T JZW Stg 4, 415hp 532tq
The brace works but the change in steering feeling is very small. It did seem to tighten up the steering a little but to be honest it did not make much of a difference. It is a pain to make, it takes several attempts to bend it correctly and get it to the correct length. But at a cost of less than $5 I can’t really complain about that. This is a good upgrade to do if you are bored.
2008 Turbo X - 19T JZW Stg 4, GS Intake & Front Mount Inserts, 3" Catless DP
2006 Lotus Elise - 6.9 lbs/hp
2005 9-2x Aero - Stg 2
1996 900 'Aero' 2.3t Sold - www.EricSaabSite.com
