Idle dropping off/misfiring/not firing on all cylinders - SaabCentral Forums
Old 31-10-05
Si's Avatar
Si Si is offline
My Saabs: Sensonic NG900T, a gagle of rusty c900's
Default Idle dropping off/misfiring/not firing on all cylinders
Can all of the above be caused by dodgy HT leads?
On the way back from my parents (about 160 mile round trip) i hit traffic on the M'way and when the car dropped to idle it stalled, then would start OK but as soon as i let the revs drop it would stall, managed to make it home(just, it died on the driveway) , then when it started it was only firing on 2/3 cylinders.
It was OK the next day, then after a short jorney (with no stalling) i started it again and is was only firing on 2/3 cylinders again, popped the bonnet and checked the HT leads, started it and it was OK again.
Please let it be the HT leads and not my Head gasket .
(ps did'nt think i'd risk the trip to USD the next day)
Psytuned 1997 900 Sensonic coupe turbo
Old 31-10-05
Matthew's Avatar
Matthew Matthew is offline
Saab Mad
My Saabs: 900 S Aero Turbo, 9-5 Aero
HT leads can cause a misfire.
Your car's problems sounds more like a failing AMM, but then the T8s don't have those. Chronic over-fuelling could cause those symptoms. Did you smell excessive levels of fuel?
Try checking electrical connections on components that have something to do with air mass/flow measurement for fuelling. The intermittent nature of the fault could point to a loose connection of some sort.
Also check that all inlet piping is secure and without leaks. When the inlet hose from my T16's turbo compressor exit popped off, the symptoms were very similar to those you describe.
The path of my life is strewn with cowpats from the devil's own satanic herd
Old 31-10-05
Si's Avatar
Si Si is offline
Default IC piping
The IC piping is always the first thing i check, mainly cos i blow them off so oftern, i even welded lips on the pipework to help keep it all together(it's no fun blowing a IC pipe whilst trying to overtake a HGV on the M'way) but i'm still getting charge seeping over 1 bar(maybe the Bypass valve?), but that's another story though!
If anything i think i'm suffering from running lean, it's nearly impossible to stop it boosting over 1 bar in the higher gears, all i do is touch the throttle and off it goes!
I'll pick up some HT leads tommorow, hopefully that will solve the problems.
Old 31-10-05
Tomarse's Avatar
Tomarse Tomarse is offline
My Saabs: LPG '80 99GL, '80 99T 2dr, LPG '93 ng900
Check your dissy cap too, especially the little sprung contact at the top that runs on the centre of the rotor arm.
Went on my 900T and on my dads 900i within a couple of months of each other.
Is the oil non- creamy and it isnt running hot or bubbling in the header tank? I also hope it isnt your head gasket. Have you plucked up the courage to do it yourself now?
Old 31-10-05
Si's Avatar
Si Si is offline
Default Hg
I'm checking the oil/coolant constantly as i'm not running a rad fan at the moment, i'll pull over and switch the engine off if the temp gauge goes over 2/3rds (it has'nt yet though).
I am getting a bit of pop bubble and crack though, but i'm hoping that it's more to do with the leaking ex man and maybe a few air leaks in the zorst.
Have'nt had the loud crack on gear change since i reworked the intercooler pipework so it must have been something to do with the length of the pipework.
Old 31-10-05
Tomarse's Avatar
Thats how mine started - then over a month or two it got to be how it was when i visited you and then not long after my oil went creamy..
My exhaust manifold has a crack in and the exhuast is blowing round the joints and it didnt pop atall after i replaced the head.
You havent noticed the car giving out the odd belch of white/grey smoke/steam when youre giving it some have you? Thinking back - I think i know when my head initially cracked as i was thrashing it along the dual carriage way and was just overtaking someone when im sure i got 10-20 seconds of smoke/steam out of the exhaust. It still ran fine though.
I also did about 10-15 miles after the oil had started getting creamy and i noticed no difference in how the car ran from normal! (though i had pulled the APC fuse and did it on base boost)
Old 01-11-05
Si's Avatar
Si Si is offline
Default Head Gasket
I guess that some problems with the HG will only appear once the engine is hot?
I'll replace the HT leads & plugs and keep an eye on oil/coolant, keep my fingers crossed in the mean time.
Cheers
Old 02-11-05
16saabs 16saabs is offline
My Saabs: 2x LPT convertible's, 1 x 900 SE
when were the plugs last changed(mileage) my father in law had a brand new talbot horizon(1993) and came on a 100mile journey and said he did not think he would get here?, car was running roughly. checked the plugs, and the gap was between 52-55 thou, should be 25, asked him when were the plugs last changed ?,the had'nt,17000mls on a set of plugs,what a -anker(yes father inlaw,also garage,as he had,had the servicing done on time/miles)new car??,things do need changing now and again. sometimes they might even look ok, but i had one go after 500mls.
Old 02-11-05
Jezzadee's Avatar
Jezzadee Jezzadee is offline
My Saabs: Yamaha FZ6 Fazer
I used to get this about once a week. I tried a new rubber IC connector, new jubilee clips and silicon sealant in turn but it still kept happening. I too have had the dubious pleasures of getting from lane 3 to the hard shoulder in heavy traffic with the engine stalled. In the end I bought a silicon humped hose, 70mm ID, from Burton Power for £10. It has never come off since.
Go Dutch
Old 02-11-05
Keijo's Avatar
Keijo Keijo is offline
My Saabs: 99 -84 T16+MS2-extra, 96 -77b
A faulty ignition amplifier may also cause trouble when it gets warm enough.
Old 03-11-05
Si's Avatar
Si Si is offline
Default Plugs
Will be doing the plugs with the HT leads at the weekend, i bought the car (parts car which i took the engine out) in May, i've been working through the service stuff gradually, only done about 2k miles on the engine since i've had it.
Alan/Craig, any idea whan the plugs were last changed??????
Old 05-11-05
Si's Avatar
Si Si is offline
Default HT/Dizzy etc
I bought some HT leads today and fitted them, also noticed that when i'd put the new distributer cap on a few weeks ago i'd managed to do it upside-down , so it was'nt sitting properly, swapped that about aswell.
It's definitley improved, less backfiring, idles a bit smoother, no bumps in the boost, not perfect yet though but i'll hopefully get a chance to do the sparkplugs tommorow and see if that helps.
Car has'nt stalled again..yet .
Old 05-11-05
ShadowWorks's Avatar
ShadowWorks ShadowWorks is offline
Banned
My Saabs: The Black Night, 900T
A plug can fail, the insulator can break down and the spark goes into the casing and not down the shaft.
Lets hope its a nice cheap easy fix like that,
I am quite good with my spark plugs and check the gap and condition of them ever 3 months or so, infact that may explain my weak idle vacuum, my plug gap my be too large? time to watch the fire works and work on the old girl, nice night for it too
Old 06-11-05
Si's Avatar
Si Si is offline
Default gremlins
I've been driving around a bit and it still seems OK, but every nown and again when i accelerate hard the car stutters a bit as the boost picks up, usually accelerates, stuters for 1/10th of a second and then accelerates some more.
It may be more to do with the turbo/IC pipework/APC/Solenoid/Bleed Valve or cuffs as it seems to happen when i hit max base boost & the APC takes over.
Once i've changed the spark plugs i'll have to investigate it a bit further.
Old 04-08-06
tonyw's Avatar
tonyw tonyw is offline
My Saabs: 1989 Saab 900i 8v Auto 4 door
Si, did you sort that stalling under acceleration out? dansaabfan is having similar problems.
