What tools do I need to take off a fender?
depends if you want to re-use the panel or not! (so if youre removeing a wing off a donor vechicle you do not want to grind it, but go ahead on the scrap one!)jetman said:No bolts a grinder wont scare off!
Thats what I was thinking too. Just cut the whole thing off and then take back to the shop/house.if you are going into a junk yard just bring a cordless sawzall and cut it right of then bring it back to the shop to break the welds
Not sure what you're asking here900t said:How can I safely remove the fender from the wheelhouse...
Take a look at Tomarse's pictures above, and you'll see that you need to remove the outer fender; then, the front suspension on that side has to go; then, the wheel housing has to be separated from the inner fender and from the bottom frame rail. It's just not a realistic proposition...or the wheelhouse from inner fender without damaging?
Do you mean that bit that i cut? If you look at the last picture it is fixed onto the car with loads of spots. You cant get at them to drill them while the wing is on - so something has to be cut somewhere.900t said:How can I safely remove the fender from the wheelhouse, or the wheelhouse from inner fender without damaging?
What was the Mexican guy doing in Scotland?If your in a hurry you can cold chisel the wing off, that's what i ended up doing with the help of a Mexican guy, he was a God send![]()
LOL, no i was a bit far from home in LA:lol: he said he was mostly Gabrielino and some Mexican, i understood the Mexican part at the timeMatt88S said:What was the Mexican guy doing in Scotland?Thats a bit far from the homeland.
