Automatic Shifter Light Replacement - SaabCentral Forums
Old 22nd October 2005
joederr's Avatar
joederr joederr is offline
My Saabs: 1998 900 SE 2.0 Turbo
Default Gear Indicator Light Replacement
I have a 1998 900 SE 2.0 Turbo, and I am going through working out all the little things that are wrong with her. She is 93k and going strong!
My question is with the lights that tell you what gear your in. I have read there are two bulbs, and one of them is out.
What I need to know is how to get in and change those bulbs.
Does anyone have a Hayes manual for the 98 900 that can help me out? Maybe someone has taken it apart and can tell me how they did it?
Here is my the things that are wrong, that is on my to-do list:
Rear window washer doesn't work
Headlight washers doesn't work
Glove compartment light doesn't work
Old 23rd October 2005
jared_kipe's Avatar
jared_kipe jared_kipe is offline
My Saabs: '97 Saab 900SE Turbo Convertible
I've taken it apart, for another reason, and I think I might be able to help.
This site helps to dismantle the dash. Once you get in there are 4 torx screws holding down the instrument cluster. Take it out and remove the large wiring harness from the back.
Now remove the several torx (I believe) from the outside casing, and the back of the cluster comes off. Do it carefully there are wires or something running between the back and front. Take note of where the wires go so you can get them back. Now all those little holes are bulbs I believe. I've never taken one out, but it looks as though you turn them and they pop out for replacement.
http://www.saabcentral.com/~munki/te...ard_insert.htm
Now if only someone could get around to answering my questions...
Old 24th October 2005
joederr's Avatar
Thanks for replying. Do I have to take apart the whole front end of the car to get to the center console (between the seats) to replace the bulbs for the gear shifter? I hope not!
I book marked the site just incase I do have to take part of it apart.
What questions do you have.. maybe you should post them like I did, each one linked together!
Let me know about the main console.. that would seem a bit excessive.
earthworm's Avatar
Saab Sage!
The gearshift position illumination works not in the '96 bluebird as well.
I suspect the cover can be pried off with a little screwdriver - most of the panels and covers seem to be very easy to remove - even the entire console..
And this should be done every so often as the console and the area between the seats can be quite the dirt and lost objects haven ..
The earthworm
'96 900S, Automatic
joederr's Avatar
Earthworm, If I figure it out, I will post pictures and let you know as well.
jared_kipe's Avatar
Oh where are the lights? I have a manual so I was thinking it would be in the instrument cluster. If its in the center console you probably just have to remove the shifter knob assembly if possible. Or maybe the whole center console. I don't know cause I have a manual and the section around the shifter is very easy to pop out.
rainmn rainmn is offline
My Saabs: '95 900S Convertible
If you have't already done it, I'll post my experience in a few days. I'm waiting for an order from thesaabsite right now, and 2 of those bulbs are part of that order.
I've had the console out before, and saw where one bulb is - Right behind the duct on the driver's side which supplies air to the vents at the rear of the console.
Where the other bulb is, I have no idea. Wasn't really looking for it at the time.
I can't see any way you could possibly replace the bulbs without removing the console first.
joederr's Avatar
I will wait for your guidance. When I do it, I plan on taking pictures of the whole process to post on my site I am building for saab repair, at least for 900SE folk.
Old 25th October 2005
Slaab4life's Avatar
Slaab4life Slaab4life is offline
My Saabs: 1997 Saab 900S 2.3L
I too am in the same boat with the shifter lights. Both of mine are dead though, so it makes for a fun time in the dark. The Haynes manual has a good write up on taking apart the centre console. You will pretty much need to get the whole thing out or slid backwards, then remove the vertical facia around the stereo/heat controls to release the front end of the gear shifter face.
As for the bulb itself PMI was kind enough to give me this information:
Article : Shifter Bulb
PartNo : 8500613
Order Quantity : 2
Lois (looking at a used car Peter wants): Peter, this car has dents in it, and it's got a cardboard steering wheel.
Peter: Just a second honey.
Lois: And look, there's no engine! It just has a drawing of an engine!
Car salesman: But it only had one previous owner....James Bond!
Peter: I'll take it!
joederr's Avatar
PartNo : 8500613
Order Quantity : 2
Thanks.. heading to E-bay to buy one now. I have wanted one for a while, not it gives me a firm reason to buy one
If anyone does this, please post here so we all can know what to expect, also any tips you have on how to do things along the way.
earthworm's Avatar
Saab Sage!
I wonder if that same part number can be used to order new bulbs from the UK....These important numbers should be listed in the owners manual, in the same high quality as used to display service for the larger bulbs(lamps).
The earthworm
'96 900S, Automatic
According to my invoice from thesaabsite, the part # for the bulb is 12798389, superceded from 8555831.
joederr's Avatar
so we have a few numbers for the same bulb....
thesaabsite: 12798389, superceded from 8555831
haynes manual: 8500613
I guess I will see if anyone local has either of them, I would hate to get it all part and not have the bulb in hand.
Old 29th October 2005
Ok, replaced the bulbs today. Couple of quick points: Yes, there are two bulbs. Yes, the part # I posted earlier in this thread must be correct, since I got the correct bulbs. Lastly, no, I didn't get any pictures. About halfway through, I thought to take them, then realized my wife had the camera. (She had the kids too, so I can't complain)
To start, follow these directions: http://www.mpperformance.com/saab-sh...ft-install.htm to get the console out. My car has manual climate control, so that part was a little different...three electrical plugs, and you have to remove the cable from the temp. control. There's a little metal clip on the cable end - pull it, and the cable can be released.
Once all that is out, remove the HVAC duct from the driver's side that runs from the dash to the rear of the console. Nothing holds it in, but you have to do some wiggling to get it out.
Finally, pop the trim around the shifter loose. Three clips hold it in place that should be pretty obvious. You won't get it totally off, since the shifter is in the way, but you don't need to. Look on the driver's side, and one bulb is obvious. The second is further back, and a little harder to see. Just follow the wires from the front bulb, since they go to the other socket. Pull the sockets out, replace the bulbs, and snap them back into place.
Put everything back together in reverse order (Don't forget the white plastic piece for the air direction control if you have manual climate control.) All together, it took me about an hour, or three beers, however you measure.
Old 30th October 2005
earthworm's Avatar
Saab Sage!
Thank you, rainman...
The DIY will save $$$ on this task alone.
Next will be to find a cupholder/change-holder as shown in one of the photos..
The earthworm
'96 900S, Automatic
joederr's Avatar
Earthworm... $19.90 listed here.. Shipping brings it up to $27.61. Its the first place I saw it listed for sale.
joederr's Avatar
Rainmn,
Great Job.. When I get my car back from the shop, I am planning on doing this too. Thanks for the link, it will be a big help when I start in on it and I am going to order the bulbs tomorrow so I will have them in hand.
I can't find the bulbs by part # on thesaabsite, can you post the link to the page? Thanks!
Til then...
The bulbs weren't listed on thesaabsite when I ordered them. I placed an online order for all the stuff I needed that they had listed, then sent a request for all the stuff that they didn't have listed. I provided them the part #s for everything, except the bulbs...they found that one for me.
joederr's Avatar
Just ordered my bulbs... $13.98 shipped.. got to love it when shipping for two small bulbs ($7.70) cost more than the bulbs themselves (2x $3.14=$6.28)
...sigh.
When I put in the part number 12798389 in the search box, it goes to a "Master Database" search with the number already in there, hit search and the one line "Application, Part Number, and Price" shows up. Click "Buy Now" and you will be taken to the shopping basket. There you can of course increase to 2 bulbs and hit re-calculate... Thanks again Rainmn.
Old 2nd November 2005
joederr's Avatar
Just got my bulbs today. My car is in the shop for some engine codes, but here is a picture of the ones I got. I forgot to say how bad my camera takes close up pictures. Thats going to be rectified soon when I buy a new digital camera.
Given the previous experience, I am looking forward to the adventure.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
