ABS or not ABS? - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9000 > Saab 9000 Workshop
Saab 9000 Workshop Saab 9000 (1985-1998) Technical Forum
Old 11-01-03
santeria600's Avatar
santeria600 santeria600 is offline
My Saabs: '96 9000 2.3 CSE LPT Auto
Default ABS or not ABS?
Dumb question of the month...
On starting my '86 9000t16 the dash light for ABS comes on. Did Saab just install the same dash for all models (meaning all the lights appear) or does my car have ABS fitted?
John.
Owned:
'80 900GLe Auto 5dr/'84 99GL/'85 900t16 3dr/'86 9000t16 Own: '96 9000CSE 2.3 Auto
Old 12-01-03
red9k red9k is offline
The easiest thing is to brake real hard on gravel or something similar!
If it sounds like the whole car is going to fall apart and the brake pedal is rumbling then you have ABS and if its not you dont have ABS
!!!! IMPORTANT !!!!
A word of advise to all of you who have ABS on your car! The most important thing when you panic brake with a car fitted with ABS system is to press the pedal as hard as you can! the ABS system works best with 40kg and more of pressure to the brake pedal! And that is probably as hard as you can press with one leg on the pedal!
So go and practise on a gravel road!
!!!! IMPORTANT !!!!
Regards
Magnus I
