| Saab 9-5 Performance, Mods & Tuning Covers Tuning & Performance modifications for the Saab 9-5 |
Thinking about having my 01 aero lowered has anyone done this if so any pictures also..pros and cons..thoughts..
| Sponsored Links | ||
Advertisement | ||
Pros:
1. Better handling 2. Looks cool 3. See #1 4. See# 2 5. Less filling 6. Tastes great Cons: 1. Bye-bye warranty, original or extended (Hirsch upgrades excluded) 2. Possibility of tire rub (dependent upon amount of lowering and driving habits of course) 3. Koni sports not adjustable whilst on vehicle |
For sure rears - can you pop off the strut tower caps on the front under the hood?You need to get to the top of the strut to do the adjustment...
maybe i am better off going to a 18inch wheel instead of lowering..thoughts..
You won't get the handling improvements associated with a lower center of gravity that springs (and shocks) will give you.
While it is true that if you go with 18s and associated tires that result in a smaller overall wheel/tire combo diameter you will have effectively lowered the car, but you will likely have no sidewall if you go that route! |
They are two toatlly different things, wheels and springs, what are you trying to achieve
The 18 with the correct tyre will be the same diameter as the 17 so no better on the arch clearance I have had the following: Stock SE suspension - awful Aero Roadholding kit - better but too soft Aero shocks and Eibach springs - better but still not right Do it right and do it once with a shock and spring package
I decline to grant to SAABCENTRAL.COM a non exclusive, royalty free, worldwide, perpetual license to reproduce, distribute, transmit, sublicense, create derivative works of, publicly display, publish and perform any materials and other information I submit to any public areas.... |
any complete kits avaliable..and if so from who..
Eibach springs and shocks suspension package for the 9-5. I believe its on PFS.
1999 Saab 9-5 SE 5spd Silver-Green/Sand Beige Taliaferro Open Intake - Forge Motorsport 007 Recirculating Dump Valve - Remus SaabSport Exhaust - Aero Clutch and PP - Taliaferro Transmission Mount - JSP 3" Downpipe w/ Racecat - JSP Stage III Tuned - Koni Fully Adjustable Shocks - Aero Springs/Sways - Silicone Vacuum Lines - PCV Update #6 - Brand new Fuel Tank and Walbro 255lph Pump - Autometer Boost Gauge - MHI TD04 Big 19T 6cm2 Turbo Awaiting Installation |
You can check out partsforsaabs.com for kits
Yeah, i thought my 2001 still handled pretty well, then i went and drove a 2004 and it was like night and day. So I too have been looking for a some dampers and springs. I've also been thinking about the bushings. |
Yeah thanks, i was thinking one thing in my head and i didn't completely write it out. I was trying to express the point that you thought i missed. In regards to the saab roadholding, it sounds like a deal, but I also thought i might try one of the other kits out there( still looking)
How old do you have to be in the US to test drive a new saab?
http://photobucket.com/albums/a227/saabnc/ |
Round here its 18 and a driver's license
You guys should really start going to www.tirerack.com they have everything you need for suspension at good prices and you wont pay the shipping from the UK (partforsaabs.com is in the uk!!!) Currently in the garage, waiting to be installed: Eibach pro-kit springs and koni sports I didnt go for the roadholding kit because I have seen lots of aero owners upgrade their suspension...so what does that tell you about the kit? waste of $600...add a lil more and get something really impressive |
Not sure if this will help you out or not, but I just put Bilstein shocks and Eibach Sport springs on my 2000 Aero wagon. I also fitted the rear camber shim kit from Taliafererro saab and the front camber kit from ??? (it was just an eccentric bolt, not sure if I needed it or not).
I did the upgrade because the rear of the wagon was sagging and burning up tires quickly (due to the camber issue). After the springs went on, I had NO drop in the rear of the car (within 1mm) and the front dropped 25mm. It looks great, but under VERY aggressive cornering, braking, or large bumps, the tires rub on the inner fender on both sides up front. No big deal really, because the entire car tightened up and feels & drives much better. It is not race-car stiff, but I have a wife who drives the car and I didn't want to "upset her" by ruining her car. Took me 4.5 hours to do the work on the floor of my garage, it was not difficult by any means, and the only special tool I needed was a spring compressor (which I didn't end up using). Next step is new tires for me...not sure what to get, but leaning towards Pirelli PzeroNero M&S. Any thoughts on this? Thanks, Rick |
can we see some pics of your car?? I have a 2000 aero wagon as well and was thinking about doing something of the sort to it...
Did you use the Bilstein Sports or HD's? Bilstein says they have rising rate valving, I think that means it gets stiffer under compression. Does it actually work?
I've heard mixed reviews on the Prielli's. Alot of the posts I've read seem to speak highly of the Goodyear F1s, Continential Sports and the Kuhmo Ecsta's. Me, I've got Fulda Carat Attiro's. Their grip is great dry or wet - can't really speak to their cornering as my '01 stock suspension wallows around corners as is. |
PLEEEAAASSEEE write back!!! |
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
