Clutch Questions - SaabCentral Forums
Old 09-10-05
randydawg randydawg is offline
New Member
My Saabs: 92 900 16V
Unhappy Clutch Questions
Are these clutches a PITA or is it me? I replaced the disc and pressure plate but can't bleed this thing to save my life. I tried the inner tube as well as a mightyvac on the bleeder nipple-both with no results. I've got to be missing something very simple-any ideas?? You won't offend me with no brainer 'have you's' since it has to be one of these.
Thanks.....
Old 09-10-05
Jezzadee's Avatar
Jezzadee Jezzadee is offline
My Saabs: Yamaha FZ6 Fazer
There's a few threads on this that might be useful:
http://www.saabcentral.com/forums/sh...leeding+clutch
http://www.saabcentral.com/forums/sh...48&postcount=7
Try a search on the words bleed and clutch for more.
Welcome to Saab Central
Go Dutch
Old 09-10-05
New Member
Default loose pressure plate bolts
In the last thread of the info sent by jezzadee (thanks), the last line states that if that doesn't work go back and tighten the loose pressure plate bolts.
Are they supposed to be loose when I'm bleeding the system? Mine are tightened up.
Please tell me this my bonehead reason I can't bleed the clutch....
Old 04-12-05
Matthew's Avatar
Matthew Matthew is offline
Saab Mad
My Saabs: 900 S Aero Turbo, 9-5 Aero
No, the pressure plate bolts don't have to be loose in order to bleed the clutch.
What exactly is the problem? Are you not getting flow of brake fluid through the clutch circuit? Or does the clutch pedal remain useless?
The path of my life is strewn with cowpats from the devil's own satanic herd
