Ok... here is the story... my friend was welding in a patch on my floorboard in the SPG the other day, and well... he had some flames that melted the fuel line and set a fire.... we got the fire out quick and no damage done, except to the fuel lines...
Here's my problem, I dont have the money to replace the lines, so I was wondering if there is some way to put a patch hose in with some fittings... compression fittings, flare fittings, plastic hose, rubber hose... what do i do? and can it be done. Thanks in advance... also what are the specs of the fuel lines.... aka sizes
1999 Saab 9-3 Viggen - Lightning Blue - T7Suite Stage 3 1991 Saab 900S Hatch - Edwardian Grey - Swedish Snow Plow 1988 Saab 900 SPG - Edwardian Grey - Wrecked 1973 Saab Sonett III - Burnt Orange |
| Sponsored Links | ||
Advertisement | ||
Matthew did a fuel line repair and, IIRC, he was able to clamp a (suitable) hose over the existing plastic line and just use jubilee clips 'cos the plastic line is strong enough...
If it's only a short length that is damaged, an in-line compression fitting might be sufficient. You'd need one for plastics that has a metal 'core' that goes inside the pipe along with the compression 'olive' for the outside. OTOH, if it's a longer length that's damaged, you'll probably need a length of pipe... Any breakers near you for bits of fuel line? |
As much as it might suck, if it were me (and I avoid work wherever possible), I'd be getting a used one from the wreckers and running it from front to rear. A patch on the fuel line would have me wondering the entire time if it were leaking back there under the seat.
Right now I have the line patched with rubber re-inforced hose and screw clamps.... it doesnt leak, i just did it to get home.... so you think if it doesnt leak, it should be fine?
Anything that works works! I'm not sure of the durability, but I wouldn't be afraid of that for a temporary fix. But I'd be thinking about it every inch I drove!
This certainly something that I would pay attention to over the winter though. |
You should buy a piece of fuel-injection rubber hose (any large autoparts store will sell it by the foot); a number of the OEM lines in the car are made of this material to begin with, so you're not compromising safety by using it.
Attach the hose with small worm-type clamps (make sure you cut the ends of the plastic line clean and square with a sharp utility knife first). I did this on my own car over a year ago, and it's still perfect |
Update....
I fixed it and it runs excellent, no signs of leaks I used 5/16 compression fittings with a 3/8 ferrule insert ground down to 5/16 (the lip), so that the line doesnt collapse.... it is mint, might not even have to replace my fuel lines now I didnt have to use any line, i just patched the two lines with the fittings.
I did make up a fuel line for a pressure gauge, from the injection rail to the |FPR. I removed the banjo and union fittings from the existing line and used those on some rubber fuel pipe. EDIT: It was ProfZ http://www.saabcentral.com/forums/sh...ad.php?t=48114
The path of my life is strewn with cowpats from the devil's own satanic herd Last edited by Matthew; 05-11-05 at 04:29 PM. |
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
