1 Burst Of Boost - SaabCentral Forums
Old 28-09-05
johnhammer johnhammer is offline
Default 1 Burst Of Boost
Hi guys,
'91 SPG, 75,000 miles, all original, no mods. I recently had a front motor mount replaced and did the belts on the front (back!) of the engine. It's probably just coincidence, but since then, I get 1 good burst of boost first thing in the morning when the engine is just warming up. The APC will go all the way to the right side of the orange & the car really pulls (just like it should). However, after that, I only get about 1/2 way up the boost gauge for the rest of the day, even if the car cools completely. What do you think? I'm wondering if I've got a boost leak somewhere? The rest of the driveability is just fine, BTW. I'm still seeing up to 28mpg with steady highway driving. Just no boost consistently.
Thanks,
John
Old 28-09-05
RoccoH RoccoH is offline
My Saabs: M91 900i 2.1 sedan & M85 900 T8 3-door
on full boost your car should be half way in the red and not half way in the orange, which would indicate you're only driving at base boost.
check for vacuum leaks to start with...
Oh, and if you want to preserve your engine and turbo: don't boost before the engine is fully warmed up!
Old 28-09-05
ejenner's Avatar
ejenner ejenner is offline
Banned
My Saabs: 900 Carlsson, 99t, 99 T16, 900 t16 vert
not sure about that - can anyone else confirm? I always thought full 'standard' boost was as described in the first post.
Old 28-09-05
pda's Avatar
pda pda is offline
My Saabs: T8, FMIC,173bhp & 228ft lb
Talking
A standard motor should Boost up to the end of the Orange & not go into the Red
its only once they have been modified that they will go into the Red
HTH Paul
_________________________________________
Sleeper baby, no show & all GO........................
Paul
Old 28-09-05
ShadowWorks's Avatar
ShadowWorks ShadowWorks is offline
Banned
My Saabs: The Black Night, 900T
I can also confirm that.
It sounds like your getting rich fueling at warm up which can give better boost and then maybe its leaning out? just a guess.
Have you cleaned you bits and bobs and made sure everything is in good working order?
Old 28-09-05
woywitka's Avatar
woywitka woywitka is offline
My Saabs: '87 900 T16 vert, 911 SC,914,W123 Diesel
on touch into the red on 94 octane is normal on stock cars too.
Old 28-09-05
Hi guys,
Sorry about the color confusion, but I get 1 full blast at the top of the orange (not into the red), then the rest of my day I'm just getting to the middle of the orange at best.
The car is recently tuned with all new ignition stuff: plugs, wires, cap, rotor. It DID give me full boost regularly, just recently something changed. I have a Turboed Miata and the usual culprit is a bad coupling between turbo pipes but everything looks ok here on first inspection.
Old 28-09-05
900t's Avatar
900t 900t is offline
Saabista
Normal situations the charging pressure shouldn't exceed 3/4 bar above ambient pressure, ie the intersection between orange and red.
Old 18-10-05
Matthew's Avatar
Matthew Matthew is offline
Saab Mad
My Saabs: 900 S Aero Turbo, 9-5 Aero
There is some APC wiring to the solenoid valve at the front of the engine bay, above the front engine mount. Perhaps some of that became disturbed, giving intermittent boost.
Try putting the old HT leads back on the car to test. Electrical interference from crap/old HT leads can mess with boost control (seriously).
The path of my life is strewn with cowpats from the devil's own satanic herd
