odometer cable question - SaabCentral Forums
Old 26th August 2005
chelo chelo is offline
Default odometer cable question
My odometer cable just starting flaking out, where it sometimes works and sometimes doesnít. I unplugged both ends and seems to turn fine when you turn the rod inside. Could it be something else that is making my odometer donít work correctly? When I pulled the end that plugs under the engine, the plastic washer came loose, and seems that in the new cable I got, the washer is stuck in there pretty good. Could this be the reason the odometer comes in and out?
If I end up replacing it, what is the best way to pull this cable out, I mean, what end first? The hole where the odometer cable comes into the engine compartment looks pretty small.
Thanks!!
Chelo
Matthew's Avatar
Matthew Matthew is offline
Saab Mad
My Saabs: 900 S Aero Turbo, 9-5 Aero
http://www.saabcentral.com/forums/sh...ad.php?t=35453
Old 27th August 2005
john-w's Avatar
john-w john-w is offline
My Saabs: 1989 T8 Special
If the speedo itself works ok then it can't be the cable. If it's just the odometer, then it's a cog thats moved inside the speedo head itself.
Do a search it's been covered many times.
Old 1st September 2005
SPG85 SPG85 is offline
I've the same problem,, and found it to be the reduction gear in the tranny where the cable connects to the tranny, , now I'm trying to find a replacement, check that you may have found the prob there also , , it's a little tight trying to pull it out, but it will come out eventually once you remove the retainer clip that is attached to one of the bolts at the Cv shaft flange,
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
