Is there a good way to check if the car is buring oil? - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9000 > Saab 9000 Workshop
Saab 9000 Workshop Saab 9000 (1985-1998) Technical Forum
Old 22-08-05
valbowski1980's Avatar
valbowski1980 valbowski1980 is offline
My Saabs: 2005 9⁵ Aero
Garage
Default Is there a good way to check if the car is buring oil?
Hi all:
I am considering a 95 CSE FPT 5-speed with 143K on it. I have read the guides and the only thing I couldn't find was how to check if the car is burning oil. Is there a clear indication (besides the ashed up rear bumper) that the car is doing this?
There is a "replacement for displacement".... It's called "forced induction".
Old 22-08-05
tristan_the_trout's Avatar
tristan_the_trout tristan_the_trout is offline
My Saabs: 1991 9000 2.3T Imola Red
Originally Posted by valbowski1980
Hi all:
check the exhaust. make sure there's no blue smoke coming out the pipe. that means you either have massive blowby, or a shot turbo. other than that.. maybe someone else can shed some light on this situation for you.
cheers..
-=tristan=-
'91 900 - R.I.P.
'91 9000 2.3L Turbo "Phoenix" - R.I.P. You will be missed
'95 900SE 2.0t Convertible - Flooded during Irene
'91 9000 2.3 Turbo Imola Red
Old 22-08-05
Superaero Superaero is offline
My Saabs: 1997 Aero manual
First, have someone start the car while you stand behind it. That'll tell you if the turbo seals might be leaking or the valve guides are going. Next, follow the car while someone else drives it and watch for the telltale smoking or puffs. If the tail pipe smokes fairly steadily when the car accelerates, then suspect the rings , if the smoke intensifies as the car picks up speed suspect the turbo seals, if it puffs periodically when the car is shifted then the valve guides are going.
Then have a wet/dry compression check done to isolate the cause. If the engine has been properly looked after it should not smoke, these engines are strong with good oil control rings. The valve guides on the older engines are a bit loose which keeps them lubricated but can lead to puffs of smoke, especially if thin oil is being used.
One exception is if the engine has been idling for a long time, say 20 minutes, it can smoke something awful for a few minutes as these engines tend to pile oil up into the clylinder head at idle and then suck it down the valve guides as soon as you begin driving. Another quirk is the older 2.0 engines tend to smoke a little if the oil is too light, say 5W 30 or even 10w30 in summer. Heavier oil or 5W 50 synthetic will generally stop this smoking.
Old 23-08-05
KevinC's Avatar
KevinC KevinC is offline
My Saabs: sorted 9K Aero 1993, 9000R, 454 GMC
Most interesting, thanks.
Old 23-08-05
Garage
Thank you very much guys. This is a great help and if all works out, I might be behind the wheel of another 9000 very soon.
Old 24-08-05
Stefano's Avatar
Stefano Stefano is offline
Saab Mad
My Saabs: 2 9ks,white '87T &'96 Silver Aero 2.0
You can remove the rubber elbow hose before the intake manifold and check if it's oily inside. If it is, probably the compressor side turbo seals are tired or gone.
Old 24-08-05
Garage
Thanks Stefano
That's in the plans as well. I hope the guy doesn't freak out when I do it thought.
