60000 mile service - SaabCentral Forums
Old 17th August 2005
SIlverAero SIlverAero is offline
Lightbulb 60000 mile service
I'm around 60K miles and wanted to know your opinions on whether i need to take my car in for service or try to replace the things(eg fuel filter, drive belt, cabin air filter, spark plugs) myself?
The only thing that really worries me is that i don't know if the ECU needs to be updated or anything if i change the spark plugs myself, because my DI cassette failed one time and while the tech replaced it and the plugs he reprogrammed/updated my ecu? Does anyone know if changing the plugs is as simple as just changing without anything needing to be reset?
Thanks
DougR's Avatar
DougR DougR is offline
My Saabs: 06 9-3 2.0T
I did it myself and was a total car n00b when I started. It was all really very straightforward stuff. I see no need to take it to a dealer if you have some time and a place to work on things.
As far as the spark plugs, I am not aware of any need to do anything with the ECU, etc. All I did was change the plugs and slap the DIC back in.
Old 18th August 2005
Kermit's Avatar
Kermit Kermit is offline
Saabista
My Saabs: 04 9-5 Vector 2.2Tid
Yep, to remove the DI just undo the 4 torx bolts and remove the connector on the right hand side (pull red part of plug out before trying to undo connector), change plugs, put DI back on (but wait 15mins to allow fluid to run to bottom of DI before starting).
DougR's Avatar
I never unplug it...oops
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
