Wheel Offsets - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9-5 Mk.I, 1998-2009 > Saab 9-5 Performance, Mods & Tuning
Saab 9-5 Performance, Mods & Tuning Covers Tuning & Performance modifications for the Saab 9-5
Old 14-08-05
Chris 9-5's Avatar
Saab Sage!
My Saabs: .
Default Wheel Offsets
The factory saab 17 wheel has an offset of ET49
If you put one on with an offset of ET40 for example does it sit further out, towards the wheel arch, or further in towards the inner wing?
Also what is the best size for 18" tyres?
Thanks Chris
Old 14-08-05
SahhhB SahhhB is offline
My Saabs: 2000 9-5, 5 speed, Nordic Stage 2
The smaller the offset, the farther out the wheel will sit.
Old 14-08-05
Kermit's Avatar
Kermit Kermit is offline
Saabista
My Saabs: Citroen C5 2.2HDi
Yep, mine are 40 offset and there is very little room between tyre and arch. The nearest you will get is using 235/40-18's..this will give a 1.72% inaccuracy of the speedo, at a speedo reading of 70mph you will be doing 71.2mph. I take it you're gonna need 18's?
Old 14-08-05
Chris 9-5's Avatar
Saab Sage!
My Saabs: .
Thanks Guys, and Kermit, not sure yet just doing some research
Old 14-08-05
Cambio's Avatar
Cambio Cambio is offline
My Saabs: '99 9-5 SE 2.3lpt, 5spd, JSP Stage 3
Isn't there a way to correct that?
1999 Saab 9-5 SE 5spd Silver-Green/Sand Beige
Taliaferro Open Intake - Forge Motorsport 007 Recirculating Dump Valve - Remus SaabSport Exhaust - Aero Clutch and PP - Taliaferro Transmission Mount - JSP 3" Downpipe w/ Racecat - JSP Stage III Tuned - Koni Fully Adjustable Shocks - Aero Springs/Sways - Silicone Vacuum Lines - PCV Update #6 - Brand new Fuel Tank and Walbro 255lph Pump - Autometer Boost Gauge - MHI TD04 Big 19T 6cm2 Turbo Awaiting Installation
Old 14-08-05
aeropilot's Avatar
aeropilot aeropilot is offline
My Saabs: MY04 Hirsch 9-5 Aero 4-door auto
What rim width are you looking at for the 18"....7.5" or 8"..?
If 7.5" then 225/40x18 tyres will be ideal, as these give as near as an identical radius to the factory fit 17" wheels with 225/45x17 tyres.
These will also be OK on 8" rims as well (this is what I have on my Hirsch wheels at the moment) but, 8" is at the far end of the rim width range for this tyre size. So, there is very little bulge in the tyre sidewall to help protect the rim edges when parking etc., and I've quite badly damaged 3 out of the 4 Hirsch alloys, within the 4 months I've had them on....
Therefore if looking at 8" rim width I'd recommend the 235/40x18 tyres.
Blessed is the sound of a ninety-two on nitro......
Old 14-08-05
Chris 9-5's Avatar
Saab Sage!
My Saabs: .
Thats handy cos the 225's are considerably more available
Thanks!
Old 14-08-05
opjose's Avatar
opjose opjose is offline
My Saabs: 9-5 Aero 2008 Metalic Black
Yes via the Tech II.
Old 16-08-05
Fliptop's Avatar
Fliptop Fliptop is offline
My Saabs: lots
No 18" option on Tech2 for 9-5s, only 9-3ss...
