turbo problem - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9000 > 9000 Workshop
9000 Workshop 9000 (1985-1998) Technical Forum
Old 5th August 2005
SAABidji SAABidji is offline
My Saabs: 9000 2.0L Turbo 16v M90
Default turbo problem
Okay. My 9000 was having trouble on hard acceleration in 5th gear. The APC/turbo gauge would go into the red (slightly) and the car would hesitate and wouldn't go faster than 140km/h. So I changed most everything I could to get rid of that problem: I bought and installed a new APC solenoid, a new dumpvalve, changed the DI-cassette and plugs... each of which made the things a tad better but wouldn't solve the problem completely. Now this morning, I decided to try and change the 4mm hoses for new ones... those looked okay to me, but you never now...
So I bought the new hoses, installed them in place of the old ones and... everything was fine! The car would accelerate normally in every gear, no problem. It would just stall a little bit at idle, but nothing to (apparently) worry about. Too good to be true...
Now I was on my way home, like 15 minutes ago. Went out of the highway. Stopped at the stop sign. First gear, no problem. Second gear, rev to about 3000... BANG! engine stopped, Check Engine Light on and all. I turn the key again, engine starts. I accelerate gently... and soon as the turbo gauge approaches the yellow zone, the engine hickups and stops, with lots of black smoke coming out of the exhaust pipe.
What the heck just happened? I sure hope it's not the turbo... any idea?
Old 5th August 2005
update: unplugged the airmass meter and now the engine runs... only the turbo won't really start but I guessit's normal. could a faulty airmass meter cause that kind of issues?
Old 6th August 2005
boxman boxman is offline
My Saabs: -
have a good look around the intercooler pipes to make sure you havent blown off a pipe, it may be on just enough to work under vacumm but once the turbo boosts blows off the pipe again
Old 6th September 2005
Yep, that was the problem indeed. Many thanks. (I was on vacation, couldn't reply earlier)
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
