How to replace rotors? - SaabCentral Forums
Old 30th July 2005
pmonfre pmonfre is offline
Default How to replace rotors?
What is involved in replacing rotors? I need to do the fronts - any special tools? Do you have to repack the bearings? What holds on the rotors?
Thanks!
Old 30th July 2005
Raven18940's Avatar
Raven18940 Raven18940 is offline
My Saabs: 2001 9-5 Aero 5spd
Not hard at all, they're "slip-on" rotors. Just take off the calipers and slip them off.
Old 30th July 2005
cryptical's Avatar
cryptical cryptical is offline
My Saabs: 2003 9-5 Aero Sedan & 2002 9-5 Arc Wagon
Out of WIS:
To remove
1. Raise the car and remove the wheel.
2. Remove the brake hose from the clip.
3. Press the brake piston back, using a pair of slip - joint pliers.
4. Remove the two brake caliper retaining bolts. Suspend the brake caliper from the suspension strut, using a cable tie.
5. Remove the brake disc's locking screws.
6. Lift off the brake disc.
To fit
1. Wash the new brake disc and check that its surface in contact with the hub is free from rust, burs and the like.
2. When fitting the brake disc, check that the hub's surface in contact with it is not rusty or dirty. Fit the brake disc on the hub, apply Loctite 242 to the locking screws of the brake disc and tighten them with a torque wrench. Tightening torque: 4 Nm (3 lbf ft)
3. Fit the brake caliper, apply Loctite 242 to the bolts and tighten them.Tightening torque 117 Nm (86 lbf ft).
4. Fit the brake hose into the clip.
5. Fit the wheel, see Wheels. Tightening torques aluminium wheel 110 Nm (81 lbf ft) steel wheel 50 Nm +2x90į , max. 110 Nm (37 lbf ft +2x90, max. 81 lbf ft)
Important
The wheel must hang freely when the wheel bolts are being tightened. Lower the car and depress the brake pedal to force out the brake pads. Check the level of the brake fluid. Drive the car on test and check the operation of the brakes.
"Trouble with you is the trouble with me, Got two good eyes but we still donít see.
Come Ďround the bend you know itís the end. Cause the fireman screams and the engine just gleams"
Old 30th July 2005
Wow! That's just what I needed. Thanks!
Old 31st July 2005
Chris 9-5's Avatar
Saab Sage!
My Saabs: .
Nice post
I had problems with No 6 as I forgot No 5
There I was hitting the disc when my son said:
"Dad shouldn't probably remove that torx screw first"
Old 31st July 2005
cryptical's Avatar
Glad I could help!
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
