Ignition Coil wiring diagram? - SaabCentral Forums
Old 30th July 2005
Oyster Oyster is offline
Default Ignition Coil wiring diagram?
I have an '89 900 N/A with the mounted ignition amplifier and I need to put in a new coil. Unfortunately, I pulled the old one out without bothering to take note of where the 3 wires went. The Bentley wiring diagram doesn't show this.
I know the red goes to positive, the blue to the negative on the coil....but where does the black wire with the capacitor that grounds to the side of the distributor go? I thought it was on the positive post of the coil, but I just need to make sure so I don't fry anything.
Old 30th July 2005
ursatz's Avatar
ursatz ursatz is offline
My Saabs: '90 900 turbo convert
Does this help? My '90 900 n/a. I think you are right.
Old 31st July 2005
ProfZ's Avatar
ProfZ ProfZ is offline
My Saabs: 1990 900S 3-door auto. 1988 900S 4-door 5-spd.
On my 1990, which has the remote amplifier (not the one attached to the coil like the '88 and your '89), the black wire connects to the coil + terminal. I'm pretty sure it's the same for all.
Old 31st July 2005
Matthew's Avatar
Matthew Matthew is offline
Saab Mad
My Saabs: 900 S Aero Turbo, 9-5 Aero
That's strange as you would have thought that the convention of black wire = negative would have been maintained.
Do coils actually work if their low-tension supply is connected in reverse?
Old 31st July 2005
Basre Basre is offline
Banned
One question: Why a new Coil??
Bosch OEM ones have proven almost 100% reliable... in Millions of Cars.. for lotsa years
. Most of the ones that were replaced as faulty were due to the ineptness of the servicing Mech.
Prolly the most reilable Bit Bosch has yet built:-) Just a thought.
Old 31st July 2005
john-w's Avatar
john-w john-w is offline
My Saabs: 1989 T8 Special
The + has the ignition feed the - goes to distributor then to earth. ie - negative earth.
Old 31st July 2005
The one that was in the car was a coil from Accel, not Bosch. I will be replacing it with the Bosch coil though. The reason I am replacing it is due to a weak, if any spark. I am also not getting an Ohm reading off the center post just terminals 3 and 4 on the coil when testing. Looks like some moisture got in there and ruined it.
Thank you for the responses!
Old 31st July 2005
eggsngrits's Avatar
eggsngrits eggsngrits is offline
My Saabs: 1991 900 16v Turbo Convertible SE
You may also try here:
http://saabpics.org:3000/gallery/album185
Mike in Nashville, Tennessee
/ @eggsngrits on Twitter
1991 Saab 900 SE Convertible / 2004 Audi A8L quattro 4.2l
Old 14th September 2005
ShadowWorks's Avatar
ShadowWorks ShadowWorks is offline
Banned
My Saabs: The Black Night, 900T
You can buy a replacment coil on Ebay, if you want something that may be a little more up market just do a search
I am thinking about using one of these coils.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=7999629400
I am told it will work on all 900 up to ,94 and its not expensive
jetman jetman is offline
My Saabs: 1984 T8
I have this burned into my memory..."blue two" in other words, the blue gets the extra wire.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
