CK3100 Install Pics - SaabCentral Forums
Old 7th July 2005
heatvent heatvent is offline
My Saabs: 2005 9-3 Linear / Premium Package
Default CK3100 Install Pics
Please post pics of your Parrot CK3100 installs. I am looking for ideas on an '05 9-3.
THANKS!!!
Old 8th July 2005
scooter28 scooter28 is offline
My Saabs: 2005 Saab 93 Arc
Default Just installed this on my 2005 93 Arc
I just did this install on my 2005 93 Arc which is pre-wired for a hands free kit. It was very simple once I found the correct harnesses; I purchased the following harnesses from Sio Communications (06-109B and 06-223B) and the CK3100 from Expansys-USA. It was all plug and play and the kit works great with my Motorola V600. I have to say it was quite a bit of research on my part but it saved lot of money as my Saab dealer wanted ~$300 just to install the CK3100. Let me know if you would like more info.
Old 8th July 2005
Can you host a picture of where you installed the remote.
FYI, I did a lot of research as well. See my post at:
http://www.saabcentral.com/forums/sh...ghlight=ck3100
Old 14th July 2005
JWadle's Avatar
JWadle JWadle is offline
Default My CK3100
Here's mine in my 2003 Vector.
Connected via Etadyne cable to mute & center speaker. Parrot microphone mounted on overhead console.
Old 14th July 2005
Rob in Atlanta's Avatar
Rob in Atlanta Rob in Atlanta is offline
My Saabs: '98 900S/ '06 9-3 Aero
What functionality do you now have? Does the built-in microphone work? Does your mute work on incoming calls? Does the cellphone audio play through your speakers? Do any of the steering wheel buttons work? If so, which ones? I'm trying to help a friend decide on whether to put a hands-free system in his 2005 Arc.
Rob in Atlanta
Old 14th July 2005
johnc_22's Avatar
johnc_22 johnc_22 is offline
My Saabs: SAAB-less
Rob, from what I understand the 2005s that have the pre-wired h/f kit can use the factory mic. Without this pre-wired harness you would have to track down the wires and wire it up yourself which is probably not worth it, IMO. I don't know of anyone who has accomplished this. This harness constitutes the TEL1 phone option and does not allow use of the built-in infotainment system and call/hangup wheel controls. It would work just like a h/f kit installed in an older hatch-based 9-3 - you need the kit's mic and antenna (unless bluetooth so you use phone's antenna). TEL2 uses the built-in phone and all the other goodies but is not available in N. America.
Old 14th July 2005
NocBlue's Avatar
NocBlue NocBlue is offline
My Saabs: 2004 93SS Nocturne Blue Metalic Linear
With or without pre-wiring you can have EVERTHING, except steering wheel button functionality, but you also gain automatic voice recognition which offsets the loss of the steering wheel buttons. I am very impressed with the Parrot CK3100. If you are prewired tel1 then get the SIO cable mentioned above if not get the etadyne tel1 cable. You will get infotainment muting, telephone displayed on SID, voice over front speakers, either built-in mic or Parrot mic, voice recognition/voice spotting, Parrot display, other Parrot extras see their web site. The installation is straight forward, you will have to upgrade to a blue tooth capable phone but any brand/carrier will work. I will post picture of mine when I get a chance...
Old 15th July 2005
Really the only thing I think I would miss would be the superior hard-wired antenna. One advantage of an in-car kit is the increased range and reception offered by a hard-wired antenna.
Rob in Atlanta
Old 15th July 2005
johnc_22's Avatar
My Saabs: SAAB-less
Are you sure the Etadyne TEL1 cable will enable the factory mic? If so that's great news to me as that's the route I'll be taking even if I don't get that feature.
Old 15th July 2005
NocBlue's Avatar
You mis-understood, the SIO cable will allow you to plug into the factory mic, if you don't have a factory mic, you can use the Parrot mic which installs in the same spot(or anywhere you want) as the factory mic.
In other words if you have factory installed pre-wiring for phone order the SIO cables. If you don't have any factory pre-wiring order the etadyne tel-1 cable. The other added benefit the factory pre-wiring provides is that you can add the cradle to hold your phone which can re-charge when your phone is docked.
Old 26th July 2005
DMBeer41 DMBeer41 is offline
My Saabs: 2005 Saab 9-3 Linear
Any update on this, with pics?
Also, where do i get this SIO cable...
I bought the connector for the 375 plug from saabcatalog...will this work just as well. I got everything working, but couldn't get sound from the speakers. Pictures of which wires connect to which for the speakers sound would be helpful. Thanks!
Live it up, shift it down, speed it up, burn the ground.
Old 27th July 2005
See my other thread at:
http://www.saabcentral.com/forums/showthread.php?t=51444&highlight=ck3100
You should find everything you need to know there.
Old 27th July 2005
gjdavies's Avatar
gjdavies gjdavies is offline
My Saabs: Saab 9-3CV Aero TTiD 180
Try the Parrot CK3500 instead. It incorporates a gsm (900/1800 only though) module that accesses your sim card data. Looks exactly like 3100 but you can then connect it to the cars antenna.
This is what I will getting next!
Old 27th July 2005
I would, but $500+ is a little more than my budget permits.
Old 27th July 2005
That's what i was following. didn't you mention that that was for the CK3000, and that you were installing the 3100 which had different wiring. I could be wrong...but i'm not sure...
Old 11th November 2005
colombo colombo is offline
My Saabs: 2003 9 Arc
Last Wednesday (09 Nov) I had a Sport Hatch as a replacement car, and this dealer (in Leuven, Belgium) are installing the display into the vent, like this:
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
