XM Radio in a Saab 9-5 anyone? - SaabCentral Forums
Go Back   SaabCentral Forums > Saab Café > The Lounge
The Lounge For Saab related posts of a non-technical nature
Old 24-06-05
jedi_master58's Avatar
jedi_master58 jedi_master58 is offline
Location: Toronto, Ontario, Canada - 2007 Saab 9-3SS 2.0T, 1999 Saab 9-5 lpt
My Saabs: 2007 Saab 9-3SS 2.0T 4cyl
Default XM Radio in a Saab 9-5 anyone?
I'm looking into getting a XM radio for my 9-5. I was wondering has anyone put one in there and you please post up some pics of it.
Also, is there anything I should watch out for, which models would be the best for my 9-5.
Thanks.
Old 24-06-05
PHAT_joe's Avatar
PHAT_joe PHAT_joe is offline
Banned
My Saabs: Cirrus White 1993 900s 16V 5-speed
it's a pretty straight forward install; pretty much the same across most platforms of any vehicle depending if you are using the aftermarket kit from Delphi and are working with aftermarket head units. I've put XM on my car, my old Jetta and my buddy's old Ranger. Tell me what equipment your working with and I will give you a write up.
Old 24-06-05
I'm either getting the:
http://xmradio.com/roady2/index.jsp
or
http://xmradio.com/skyfi2/
I like the Delphi skyfi 2 better.
I will be using the FM modulator though.
Thanks
Old 25-06-05
MX-5.0 MX-5.0 is offline
My Saabs: '05 9-3 Arc, '92 V8 Miata, '96 Miata
Get a Proclip for the 9-5. I just installed a Roadie into our 9-3. I used the ProClip Console Mount (# 833484) to hold the unit and for now I've just tucked the wires under the creases of the center console and but the antenae on the rear window sill.
Not too difficult and for now I did it with no tools (save for drilling the ProClip screw in the Roadie bracket). That AUX input in the 9-3 is a great feature (needs a ground isolator however as there is some electronic whine present).
Old 27-06-05
PHAT_joe's Avatar
Banned
if your looking for a cleaner install, i'd pick up an aftermarket reciever like pioneer or sony, both of which have built in XM tuners as well as some other nice features and are priced starting around $130 US and up. then i would get the Terk Universal Tuner which should be about $50 US, and add an adapter for your reciver (they make specific ones for differnent brand of reciever).
the install requires some minimal skill (you should know how to install a stereo at the minimum) and might take you an hour tops depending if you have all the right tools: wire cutters, electrical tape, phillips head and flat head screw drivers, maybe some hex wrenchs, a flashlight.
for the following i assume you have removed your stereo and are using an aftermarket replacement. normally the easy part is positioning the antenna, usually placed on the roof of the trunk so it will recieve the best sattelite signal. your next job will be to run the antenna wiring from the rear to the front (this can be time consumming but you can make it look stock if you route the antenna wiring through the trunk lid, under the rear seat, and then under the kick panels and up into the dash via the center console). hook the antenna wiring up to the universal tuner which may be located within the dash if you have space. then you may connect the universal tuner to the appropriate adapter for your reciever. finally connect the adapter to the reciever itself with the supplied cable.
now to power everything up:
assuming you've installed you aftermarket reciever, you want to take the power lead (yellow -from the battery) and splice it so both your reciver and your tuner recive power. you may use the same ground for both the reciver and the tuner.
side notes: the reciver adapter and the tuner connect via RCA audio cables, the adapter and the reciver connect via [an IP-BUS connector in pioneer; possibly similar with Sony, Alpine, etc.], this is the same plug you would plug in a CD- changer or an MP3 player into. check the power drain on your battery! some cars vary in how their stereo electronics are set up and hooking the power to the receiver and tuner might drain the battery if things are not hooked up correctly. after the install is complete, turn on the radio (this will also turn on the XM) and position the antenna if need be to recieve a good signal. the car should be parked out side, with an unobstructed view of the sky if possible. tune the stereo to XM channel 1 i believe and you should hear people talking about activating your radio, etc. this is the preview channel, if you hear this then you are good to activate your XM service. i recommend going online to XMradio.com and setting up an account, they might waive the activation fee if you do this online. go through the motions on the web page and let your radio stay on for atleast an hour -and make sure its tuned to channel 1. your channels will begin to download and within an hour or so you should be able to browse through about 250 stations. you might notice signal loss when travelling though tunnels and under bridges or though cities with large buildings that obstruct the sky, also in some rural areas the signal might be weakend somewhat. overall expect audio quality to be that of an mp3, about 128 kb p/s so it won't be CD quality. i've had mine for about 2 years andabsolutly love it, some of the DJs are annoying (like Bhodi on XM 48) as he seems to be ignorant as well as some of his callers. you will not likely get any advertising on most of the music channels except the ocassional XM radio product being hawked - again on XM 48.
if you have any questions then feel free to ask and send pics if possible. look to spend close to $300 for everything, initial setup and tax included. the subscription rate is $13 per month and $9 per month for subsequent radios.
Old 28-06-05
Copey's Avatar
Copey Copey is offline
Here is my install that I did on my 2003 9-5.
http://www.xmfan.com/viewtopic.php?p...hlight=#276889
