Diagnostic connector - SaabCentral Forums
Old 16th June 2005
stevosdiesel stevosdiesel is offline
New Member
My Saabs: 1995 900 2.3 non turbo 4 door 5 speed
Default Diagnostic connector
I need a wiring diagram for a 1995 900 2.3 non turbo in cab diagnostic connector & a way to retrieve the codes.
Thanks Stevo
Old 16th June 2005
JMarkert's Avatar
JMarkert JMarkert is offline
My Saabs: 2004 9-3 linear
Welcome!
The connector is under the dash above and between your knees while you're driving.
The procedure for pulling the code is on Munki's site here:
http://www.saabcentral.com/%7Emunki/index.htm
I THINK you need to use the flash procedure since your car is OBDI not OBDII. I've used it on my old car, it's pretty easy to do unless you get distracted counting flashes.
If it does turn out that a 95 is OBDII instead, then any cheap code reader will work (and autozone and other chains can pull the codes for free).
Old 17th June 2005
New Member
I also need to know which wires go where on the connector since somebody done tore it up.
Thanks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
