| Saab 9-5 Workshop Saab 9-5 Workshop (1997 to 2010) Technical Forum |
My heater sometimes blows cold when it's supposed to be hot and vice versa. I've also noticed that when I push the recirc button it doesn't light up and sometimes a message comes on the SID - something like: "recirc pump...AC blah blah)
Does this type of failure (assuming it's some kind of pump) throw a code? Also, any of you blokes had these symptoms and a possible fix? Thanks - Oh, almost forgot: 1999 Saab 95 SE coupe, V6 Turbo |
| Sponsored Links | ||
Advertisement | ||
Pmonfre, unless the V6 has a different SID to the 4 cylinder there's no such warning message. There's only the following in its armoury....
FRONT LIGHT FAILURE REAR LIGHT FAILURE FOG LIGHT FAILURE BRAKE LIGHT FAILURE TEST BRAKE LIGHTS WASHER FLUID LEVEL LOW FILL COOLANT FLUID REPLACE KEY BATTERY KEY NOT ACCEPTED SERVICE THEFT ALARM TRANSMISSION OVERHEATING TIME FOR SERVICE All the RECIRC button does is close a flap to prevent outside air entering the vehicle, i've never heard of a pump in the system. Re RECIRC not displaying, AUTO won't display on my ACC panel due to the pixel problem. To check for fault codes in the ACC, press AUTO and OFF simultaneously, this will bring up two numbers on the left and right of the display, let us know what they are and we can progress from there. |
I'll check it out and report back tomorrow.
thanks, Kermit |
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
