wont start when hot. - SaabCentral Forums
Old 12-06-05
potto potto is offline
My Saabs: 1991 900s ltp
Unhappy wont start when hot.
my 1990 t16s wont start when the engine is warm. when i turn the key the fuel pump switches on, the engine check light flashes on and off,aloud clicking can be heard from the fuel pressure regulator and the ecu..the engine wont start for 15ish mins and then will start fine.if i try to start the engine while the check engine light is on it will fire then idle erratically then stall. please help!
Old 12-06-05
Jezzadee's Avatar
Jezzadee Jezzadee is offline
My Saabs: Yamaha FZ6 Fazer
Could be a faulty NTC sensor. Details here on where it is and how to test it.
Welcome to Saab Central
Go Dutch
Old 15-06-05
Default wont start when hot
just replaced the ntc sensor and cooling fluid still have mad clickin and whirring even after ive turned the key off. Ive also cleaned aic and the throttle body butterfly. Could it be vacuum leak?
