For those of you with aftermarket springs.. - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9-3 SportSedan/Convertible ('04+)/Combi, 2003-2011 > Saab 9-3 SS, Combi & Convertible Performance, Mods & Tuning
Saab 9-3 SS, Combi & Convertible Performance, Mods & Tuning Covers Tuning & Performance modifications for the Saab 9-3 Sports Saloon/Sedan, Combi & Convertible
Old 19-05-05
M4Gunner's Avatar
M4Gunner M4Gunner is offline
Default For those of you with aftermarket springs..
I plan on upgrading my springs, however, i want to hear what you guys have to say.
1. what brand did you go with?
2. how many miles were on the factory suspension when you made the upgrade?
3. did you stay with your factory dampers?
4. .. and the most important... would you do it again? why?
PS, for those that had the infamous suspension "knocking" before you upgraded, does it still happen?
Old 20-05-05
M4Gunner's Avatar
hello?!... anyone home?
Old 20-05-05
93t's Avatar
93t 93t is offline
My Saabs: 9-3 SC Aero 2006
Have Eibach springs installed..
Had them installed when the car had run 2000Km
Still have the stock shockabsorbers, works great
Knocking not existing, didnt have it before either .. transfered the rubber hoses from the stock springs to my Eibach springs.
Old 20-05-05
Viscouse's Avatar
Viscouse Viscouse is offline
My Saabs: 2003 9³SS Arc, 100k+ miles
This would work better in the tuning forum.
Off we go.... . . . . . . . . . . .
I love the WWW. With the advent of the Rock Paper Scissors Forum, and the
Zombie Preparedness Initiative Forum, I'm ready for whatever life decides to throw at me.
Old 22-05-05
SeanArc SeanArc is offline
My Saabs: '03 Arc, BSR stage 2
gunner-
i jsut got the H&R springs from tirerack installed...i love them, lowered the car about 1/4" and it looks great. i didnt change anything else, just the springs, so the rest of the suspension is stock. the ride is a little harder and sportier but nothing over the top, still nice
Old 23-05-05
JWLANKY's Avatar
JWLANKY JWLANKY is offline
My Saabs: Audi A6 ex9-3 Hirsch CV 93t 900s
Seanarc, When you said 'stock', did you have the sports chassis fitted or the standard suspesion?
Old 23-05-05
skye2000 skye2000 is offline
Question
For those of you who are lowering your suspension, what model car are you driving? I have a Vector and it's already lowered, so i'm curious to know if you're lowering them even more.
Old 23-05-05
Saba's Avatar
Saba Saba is offline
No, you can have it back
Old 23-05-05
its standard suspension, no sport chassis... i could use some strut or rescue bars though to get rid of some of the sway
Old 23-05-05
JWLANKY's Avatar
If the body roll bothers you, you might be better starting off with the sport chassis upgrade kit, which includes the sway bar upgrade. Most people seem quite happy with the performance of this kit (but i think the sway bars are quite time consuming to fit).
Old 23-05-05
M4Gunner's Avatar
Originally Posted by SeanArc
gunner-
how many miles on the shocks?
Old 24-05-05
93t's Avatar
93t 93t is offline
The H&R kit comes in two different hights - 30mm or 45mm
The 30mm is very similar to the Eibach kit and doesnt affect the comfort that much.
But the 45mm kit lowers the car pretty damn much and the comfort with that kit sucks.
I have tryed them both..
Old 24-05-05
boenka boenka is offline
My Saabs: 9-3 aero 5sp 2004
Question h&r
93t, did you get the chance to drive a demo somewhere or did you find out the hard way by purchasing and fitting two times? any recommandations? did you also try the eibachs or other brands? Tx for the reply!
Old 24-05-05
93t's Avatar
93t 93t is offline
I have tried a friends SS with the 45mm kit and I didnt like it, the looks is great but the ride comfort sucks.
I have the Eibach kit on my own car.
Old 24-05-05
getting curious now..
what was the reason for changing for you? handling or looks? are you happy with the eibachs and what is the difference in feeling to the stock aero suspension? less roll, less understeer? harder ride? is your front spoiler still the original one?
was it expensive to get it mounted?
Old 24-05-05
93t's Avatar
93t 93t is offline
The difference between stock and Eibach isnt signifficant at all, the looks are greatly improved but the comfort havnt changed much.
The handling has improved greatly, I have tryed the car at the track (Knutstorp raceway) and it was great to drive.
The front spoiler is still stock
Mounted the springs myself and it wasnt that hard at all.
Old 24-05-05
JWLANKY's Avatar
93t, Im about to purchase the Eibachs as the feed back so far seems good, and if they're good enough for Hirsch, then they're good enough for me.
How long did it take you to fit them, and was there an special tools required (other than a spring compressor)?
Old 24-05-05
M4Gunner's Avatar
for you guys that are replying about having the springs in, could you do me a favor and read the first post, and reply w/ that info. im trying to get an idea how many miles were on the factory setup before and after, and how the shocks/struts are holding up after the mod. thanks
Old 24-05-05
93t's Avatar
93t 93t is offline
Heres a guide I wrote to a member through PM, hope it helps:
Front:
*Remove wheels
*Loosen the brake line
*Loosen the ABS cable bracket
*Loosen the upper nut to the sway bar rod 18mm
*Loosen the two nuts on the strut 18mm
*Open hood
*Loosen the three 13mm bolts holding the strut from above
*Now the strut is loose and can be picked out
Heres where you need the spring tensioner.
*tension the spring
*loosen the upper nut (21mm) on the strut, when using a pnematic air gun you dont need any special tool to hold the shock rod.
*lift away the lid, upper bearing unit and the rubber thingy
*untension the stock spring and lift it off the strut
*remove the rubber hose attached to the lower part of the spring.
*reattach the hose to the new spring.
*put the new spring on the strut,
*tension the spring
*mount the rubber casing, upper bearing unit and the lid
*tension the 21mm nut with the power gun
*reassemble starting with the three 13mm bolts inside of the hood.
Rear:
*Remove wheels
*unhook (10mm) the arm on the little measuring box connected to the suspension arm (only when the car is equipped with Xenon headlamps)
*Loosen the nut on the outer lower part of the steering knuckle (the aluminum suspension arm is supposed to come down)
*Ram the bolt out with a hammer carfully as the spring tensions the suspension arm.
*after bending down the suspension arm the spring should be loose
*remove the upper and lower rubber bushing from the spring
*Reattach the rubber parts to the new spring
*Position the new sping
*Use a jack or similar to wind up the suspension arm compressing the spring.
*Ram the bolt in the steering knuckle when the holes from the suspension arm are aligned.
*Tension the nut
Finished!
Hope you can understand it all, my technical English is rather limited.
Old 24-05-05
JWLANKY's Avatar
93t, Thats great, and your techinal English is pretty good - especially using the word 'thingy'!
I think i'll be placing an order for the Eibach's before the day is out. The only tool i wont be using is a air gun, i assume that i may need to secure the strut in someway when using manual tools, but i'm sure it wont be a problem.
