Symptoms of worn MOTOR MOUNTS... - SaabCentral Forums
Old 3rd May 2005
saabscania900 saabscania900 is offline
My Saabs: '93 900S, '93 9000 CSE, '94 9000 AERO
Default Symptoms of worn MOTOR MOUNTS...
My shifter moves ALOT when I accelerate and let off the accelerator when moving. I suspect the motor mounts. When I cruise at about 65/70...I get vibration and the shifter vibrates like crazy. If it is the motor mounts...are these hard to replace?
THANKS!
Old 3rd May 2005
eggsngrits's Avatar
eggsngrits eggsngrits is offline
My Saabs: 1991 900 16v Turbo Convertible SE
Can be the mounts, yes -- they will allow engine and tranmission movement that makes the shifter move.
Shouldn't be too hard -- check the Tech Help section on the above tab and search the board for motor mount or engine mount.
Mike in Nashville, Tennessee
/ @eggsngrits on Twitter
1991 Saab 900 SE Convertible / 2004 Audi A8L quattro 4.2l
Old 4th May 2005
john-w's Avatar
john-w john-w is offline
My Saabs: 1989 T8 Special
Open the bonnet/hood & get somebody to pull away slowly in the car while you watch the engine. With worn/shot mounts you will see the engine lift on pull-away.
Old 4th May 2005
Oyster Oyster is offline
If it's the motor mounts it will vibrate the fillings out of your teeth while stopped at a light as well.
Old 4th May 2005
maclif maclif is offline
If your shifter is moving around that much - it may be the shifter itself is loose. I had the same thing and though either my motor mounts, clutch, tranny or linkage bushings were bad but it ended up the four (I believe) screws holding the shifter in place (located under the shifter boot) were coming loose.
Old 4th May 2005
DanComden's Avatar
DanComden DanComden is offline
My Saabs: '85 900T(x2), '94 9000 Aero
I'm pretty sure my mounts are good -- things don't shake around much, and the engine doesn't seem to move under load. I like the idea of standing outside the car while someone else drives with the hood/bonnet up and will give it a try.
What I do experience is that the shifter will pop out of 2nd on a rough road. Shocked me the first time it happened --I thought the transmission had disintegrated. Now when I'm in 2nd for long periods of time on a bouncy gravel road, I have to remember to restrain the shifter while driving. Anyone else experienced anything like this? Is it cause for concern or "normal" behavior? Other gears seem to hold fine and not shake around nearly us much under the same conditions.
This is in my '85 turbo that has 230K miles of experience. I don't know for certain, but I think the transmission and engine are original.
-*- Dan
Old 4th May 2005
eggsngrits's Avatar
Again, popping out of one gear could be due to any of the above. I've heard that you can test the mounts by opening the hood, putting the car in gear with the engine off and rocking it back and forth. If the engine moves, the mounts are probably bad. You may want to search for more information.
Before you go out and buy and install new mounts, I would check the shifter for proper fit and adjustment. Just easier and cheaper.
Old 4th May 2005
ProfZ's Avatar
ProfZ ProfZ is offline
My Saabs: 1990 900S 3-door auto. 1988 900S 4-door 5-spd.
Another easy check is to look at the front engine mount--the one attached to the trans and the front crossmember, near the base of the rad.
These can self-destruct over time--the metal fatigues and breaks near one of the bolts holding the mount to the crossmember--but are the easiest (and cheapest) to replace. Worth a look
Old 3rd December 2016
ghia ghia is offline
New Member
My Saabs: 91 sAAB 900 TURBO
I have a 91 Saab 900 turbo automatic -- when I pull off in a more acceleration the transmission makes almost grinding noise when its shifts to 2nd gear, however, when I pull off slower the noise does not exist - could it be the motor mount or does it sound more like the transmission
Old 4th December 2016
secondsaab's Avatar
secondsaab secondsaab is offline
My Saabs: '91T16Vert/'92T163dr/Frknblue/'989000CSE
faulty motor mounts....Ive had numerous, never heard a grinding, even with one mount completely sheared in half. Quick way to rule that out is to open the hood and do a brake torque. Make note of how the engine raises and lowers meanwhile, it should raise some but not greatly. If you don't know how to do a brake torque google keywords, "drag strip" "race car" "big block" "torched"..so your expectations are managed correctly.
Old 5th December 2016
Jim Mesthene's Avatar
Jim Mesthene Jim Mesthene is offline
Saabista
My Saabs: Wife's 9-3
See if the downpipe from the Turbo to the Cat is positioned properly. Sometimes it contacts parts under heavy acceleration that it does not normally. Look for a shiny worn spot at a possible point of contact when the engine torques over.
The fact that there's a Highway to Hell and only a Stairway to Heaven says a lot about anticipated traffic numbers...
peva's Avatar
peva peva is offline
My Saabs: '94 T16 Ruby 3dr, '93 T16 Ruby Vert.
Also check the bracket from the downpipe to the gearbox is secure and intact. These have been known to fracture and cause vibration.
Worth checking your shift stick too. These are known to fracture at or near the internal ball with heavy shifting causing the shift stick to vibrate.
secondsaab's Avatar
Says he had an Autobox.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
