Fuel Filter replacement instructions - SaabCentral Forums
Old 8th April 2005
xxxxxxxxxxxxxxxxxFinn's Avatar
xxxxxxxxxxxxxxxxxFinn xxxxxxxxxxxxxxxxxFinn is offline
Guest
My Saabs: 2000 9-5 "TrollSport"
Thumbs up Fuel Filter replacement instructions
Fuel Filter change every 60,000 miles or before. Takes about 45min. Easy job to do even for a novice car tinkler
CLICK THE PICTURE TO GET FULL SIZE
Old 10th June 2005
serencavalier's Avatar
serencavalier serencavalier is offline
My Saabs: 9-5 SE V6
Thanks for the help Finn...always a pleasure!
Old 11th August 2005
nourdmrolnmt1 nourdmrolnmt1 is offline
wrench/socket sizes you will need:
18 mm wrench for Front bolt
20mm wrench for Rear Bolt
dont know size of the fittings on the Filter itself as i just used an adjustable wrench to hold it.
my screw that goes into the frame was a 3/8" screw, dont know why.
thanks just did it
Old 13th August 2007
mattzat mattzat is offline
Just did this operation. I bought a generic substitute from the local auto parts store. The damn thing is the identical shape, however contains no arrows (to ponit toward engine) and it is actually in a backwards configuration.
What i mean is that it looks identical but you have to put it in the way which looks backwards. Just thought I'd post this note to hopefully save someone the headache I had - trying to figure out how i managed to put it on backwards when the bolts are actually different sizes.
Old 27th September 2007
min9min9 min9min9 is offline
My Saabs: 2003 9-5 Aero
Default Bosch filter
Hello everyone,
I just ordered my replacement fuel filter and found that the threding in the hole on the tank (going into the filter -> ) side is loose and when I shake it, it raddles... is this normal or did I get a bad part??
Anybody else notice this with this part???
Old 14th March 2008
jfoxx jfoxx is offline
My Saabs: 2001 9-5 SE V6
That tiny image looks really helpful, but when I click it I get a 503 error. Does anyone else have this problem? Does anyone else have a link to this same information?
Old 14th March 2008
Bigsky's Avatar
Bigsky Bigsky is offline
My Saabs: 2002 93
I can't get the link to work?
Old 14th March 2008
Are you asking me? I'm confused.
Old 14th March 2008
MacNoob's Avatar
MacNoob MacNoob is offline
My Saabs: 01 9-5 Wagon (RIP); 05 9-5 Aero (gone)
The linkey doesn't work for me either.
Old 14th March 2008
Chris 9-5's Avatar
Saab Sage!
My Saabs: .
A little better
Old 14th March 2008
Al's Red Wagon's Avatar
Al's Red Wagon Al's Red Wagon is offline
My Saabs: 1999, Cayenne Red 9-5, 2.3 Wagon
Another DIY
Old 14th March 2008
Noice! Thanks guys. Now I have my Saturday project.
Old 26th April 2008
crosseye crosseye is offline
My Saabs: 1999 9-5 SE
Yeah, I'm gonna take this one out when I do the ATF today. Great tuts guys.
Old 1st November 2008
djdube525 djdube525 is offline
Finally got around to changing my fuel filter (122kmiles )
Anyway... just wanted to say thanks for the pics/guide.
Everything went very smoothly thanks to them.
Thanks again!
Dave
Old 9th February 2009
tsutte01's Avatar
tsutte01 tsutte01 is offline
My Saabs: 2003 9-5 2.3 lpt
Default Fuel Pump Fuse
I just changed my fuel filter this last weekend. In my 2003 2.3lpt, the fuse for the fuel pump is fuse #15 not #19 as the WIS states. Has anyone else seen the same? I am not sure if this a difference between NA cars and the rest of the world? Anyhoo, all went well and I guess my suggestion is to look at the door to the fuses to verify which one is the fuel pump fuse.
Old 18th June 2009
camaro02dk camaro02dk is offline
Ha going to do this on the car, has not been done since 60K miles and the car is now 190K miles.... yeah good one I know...
Old 14th July 2009
zef95's Avatar
zef95 zef95 is offline
My Saabs: 2002 9-5 Linear Wagon Stage 1
Just did the fuel filter today. Thanks for the info, everyone.
Just for the record, my WIS and cover panel confirm it is #15. The WIS says that pre-02 cars use fuse no. 19.
Old 8th June 2011
ski ski is offline
My Saabs: 02 95 aero
thanks for the write up, just did mine today, i'd say 45mins is a very conservative estimate
151,000 miles and finally a new fuel filter, oops
Old 9th June 2011
fob fob is offline
My Saabs: 2005 9-5 Aero
Anyone know when they changed for the updated "quick connect" style filter instead of screwed connections? I feel my 05 9-5 might be affected by the switch.
Old 9th June 2011
ski ski is offline
found your answer on eeuroparts. If you go to 2005 9-5 filters, this is what it says for the NEW quick connect filter: "VIN# 53510416 on" otherwise you have the old one
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
