9000 cde auto 20ltr turbo,starting/running problems.. - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9000 > Saab 9000 Workshop
Saab 9000 Workshop Saab 9000 (1985-1998) Technical Forum
Old 05-04-05
9000 cde at litton 9000 cde at litton is offline
My Saabs: 1993 9000 cde
Question 9000 cde auto 20ltr turbo,starting/running problems..
Hi, i hope you can help.
i have a k reg 9000 cde auto low pressure turbo which i bought only a week ago.it ran fine for a day but scince then it has been stalling at junctions and overfueling(black smoke from exhaust)it will only startif i hold the throttle open and i have to hold the throttle open to keep it going.
i have changed the air mass meter and temperature sensor but this has made no difference.i have also changed the direct ignition cartridge.
Can anyone help?
Old 05-04-05
franciscomurat franciscomurat is offline
New Member
My Saabs: 9000cde 2.3 eco
hi,
Try the oxygen sensor(lambda sensor) overfueling is a classic sympton as it sends wrong signal to ECU,it will stall just like it has the choke on.mine had same problem and now is ok.
good luck.
Old 06-04-05
Thumbs up many thanks
thankyou for your advice mate i will give it a go.
leigh
