MPGs - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9000 > Saab 9000 Workshop
Saab 9000 Workshop Saab 9000 (1985-1998) Technical Forum
Old 06-11-02
NickP NickP is offline
Default MPGs
HI,
I know this subject has been talked about many times b4 but I'm new(ish) and didn't have a 9k until recently.
Anyway, just been chatting with my bruv who has a 900 Aero ltp and discussing MPGs, he is getting about 25 avarage to the gal and I'm getting about 23 (short runs not too havey footed) and 27 on long runs.
From what I have read in past threads people are getting different mpgs with the same driving style, not that I notice much difference if I drive like a granny or have a heavy right foot (only the length of the trip seems to make a difference). Some people are getting much better mpgs than others (like me!)
What I would like to know is, is there a way to check if the fueling is correct and can anything be done to fix it?
Anyway, to put thing into perspective, I didn't get a 9K for it's fuel economy but was just wondering if there was something to check/fiddle with...
NickP
'94 9000 CSE 2.0lpt in need of a tweak or two!
Old 06-11-02
Ken Ken is offline
I have more or less the same model as you and never go below 31...a long journey gains me only .2 by the computer(which is known to be less than accurate anyway) My driving could be described as enthusiastic(!) but I don't thrash the car especially when it's cold. Try working out the fuel manually to see of it matches the readout
Oh, and you may have noticed that resetting the computer means waiting many,many miles before getting a serious readout
Old 06-11-02
Guest Guest is offline
Just a quick check- you are reading "MPG Imp" not plain "MPG" as this would giver you a lower reading. You might want to check the accuracy of the gauge with a brim to brim fill.
Old 06-11-02
Matt Phelps Matt Phelps is offline
I only had my car a few days before it broke down (see other threads) but seemed to manage around 29 mpg on average. That's on mostly motorways and B roads.
Old 06-11-02
The comp' settings are in the IMP mode, could be faulty but at the rate I have to fill the tank I think it's quite close to the true mpg. It's doing 12L/100KM when you flick through the other settings.
It's had a service, new filters etc and runs ok exceept for an slight hickup now and then when pulling away from a roling start in second. The Sparks are gapped correctly.
NickP
Old 06-11-02
BillJ BillJ is offline
My Saabs: Error 404
Nick, I also have a 2.0LPT (manual). I assume yours is manual? I can get (at a push) 35mpg on a long motorway journey, but that's hard to achieve. It averages about 25mpg. On a 2.0LPT auto, I can also coax 35mpg on a long motorway run (again, just), but average about 22-23.
www.saab9000.com - everything you ever wanted to know about the Saab 9000
www.saabits.com - stuff to help keep Saabs on the road
Old 07-11-02
Yes, the car is a manual, the max I can get is just under 27 and at the moment it's 23ish on my short .
Could be that it's running a bit rich. On my ZX there is a manual mixture adjustment pot that comes out of the ECU. I would guess that the Saab's ECu dose not have an manual tweakery available.
I did read somplace that if the O2 sensor is a bit dodgy that it could cause an over richerning (?) of the fuel mixture. But it looks like a new one in there...
Just had a quick look on saabnet's bb and spotted someone talking about the same thing! Looks like I'm not alone in the wondering about why the same model car give different mpgs...
NickP
