Hiya
My tracking was out so needed to adjust, the track rod locking nut has been rounded and is seized. Decided to replace track rod ends, I may have to butcher this to get this out . Here's the question, if I knacker the thread on the inner track rod (connecting to the steering rack) can this be replaced EASILY or do I have to replace the whole steering rack. (Bentley bible does'nt mention about inner track rods, SAAB Central do sell them though) Any help would be much appreciated before I start work and scrapping the skin of my knuckles and the swearing commences. Thanks Mick |
| Sponsored Links | ||
Advertisement | ||
Even if it is rounded, I think you could spray some penetrating oil, let it sit, then get a tight vice-grips on the rounded nut.
Thanks, I think that will be my first plan of attack, in the past I have encased the nut with a plastic bag, seal it, then fill the bag with penetrating oil, leave overnight. Sometimes that does the trick.
Anyway thanks for the reply. Mick |
Soak with penetrating oil before then heat(propane etc) when you come to try and loosen it.
I started the job, managed to losen the nut and then decided to invest in a mech after hitting the ball joint seperator repeatedly for 30 mins with no joy. One of the x-mech's i worked with had a good laugh when he found out what i was hitting it with....a large rubber mallet |
I tried to replace the track rod, but you can't get to the nut to undue it without removing the rack. So at that point I replaced the rack!
Thanks for the replies chaps, have managed to free it, covered the nut in a plastic bag, and filled it with penetrating oil overnight, have tried this trick with rusty nuts on Landrovers.
Cheers Mick |
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
